Rivet shank size
Caswell
First Name: Dean
Last Name: Brevit
Rivet shank size
Post by Caswell » Sat Dec 25, 2021 6:03 pm
Just started taking my car apart and I will be removing the running board brackets tomorrow or the day after, I'm going to center punch them and drill the rivet head centers, does any one know the rivet shank size, I could use different size bits until I get the right one but if somebody knows it would help, trying to not over drill bracket or frame. Pictures below of bracket type, brackets will not be reused (speedster).
RGould1910
Last Name: Gould
Re: Rivet shank size
Post by RGould1910 » Sat Dec 25, 2021 6:13 pm
1/4" shank I recall
Aussie16
First Name: Warwick
Last Name: Landy
Post by Aussie16 » Sat Dec 25, 2021 6:58 pm
Rather than drilling, If you have a good heavy cold Chisel, chiselling the heads off from inside the chassis rail is easy. !/4 " is correct. I but the rivets from Langs.
Post by Jerry VanOoteghem » Sun Dec 26, 2021 7:53 am
My approach would be to grind the heads flush with the running board bracket, then drive the rivet out with a punch. If they're still too tight, drill a smaller hole in the rivet, but not all the way through. Put a punch in the blind hole and drive the rivet out. The smaller blind hole allows the rivet to collapse. This way, you don't mess up the holes in either the bracket or the frame by being just a bit off with a full sized drill.
Caswell
First Name: Dean
Last Name: Brevit
Post by Caswell » Sun Dec 26, 2021 12:45 pm
Thanks all, I removed them last night, spring loaded punch, 1/8" pilot hole followed by 1/4" drill, rivet heads all fell off.
Post by Jerry VanOoteghem » Sun Dec 26, 2021 6:44 pm
That'll work too :D
