Top Bow rivets
GG Gregory
First Name: GG
Last Name: Gregory
* REQUIRED* Type and Year of Model Ts owned: 27 Roadster
Top Bow rivets
Post by GG Gregory » Thu Dec 30, 2021 3:50 pm
I’m going to be rebuilding the Top Bows for my 27 Roadster. I’d like to use solid aluminum rivets instead of original steel type. Any ideas where to find solid aluminum rivets ? Everything I find local is to short.
Re: Top Bow rivets
Post by Norman Kling » Thu Dec 30, 2021 4:01 pm
I just used a flat head bolt without a nut. They are covered by the wrap on all bows anyway, so they don't show.
Jim Eubanks
First Name: Jim
Last Name: Eubanks
* REQUIRED* Type and Year of Model Ts owned: 1926 touring, 1927 cpe
Re: Top Bow rivets
Post by Jim Eubanks » Thu Dec 30, 2021 5:40 pm
Gary, WW Granger has alum. rivets in various lengths. They have a store in W Knoxville. Look up WW Granger on the net and query solid rivets.
Last Name: Strange
Re: Top Bow rivets
Post by CudaMan » Thu Dec 30, 2021 5:58 pm
I used these on my 1924, they were aluminum, I was able to squeeze them in my bench vise. To be sure, you can call Lang's first to make sure.
https://www.modeltford.com/item/3897XR.aspx
Last Name: Juhl
Re: Top Bow rivets
Post by Oldav8tor » Thu Dec 30, 2021 8:59 pm
Aircraft rivets - Try Aircraft Spruce
First Name: Jeff
Last Name: Humble
Board Member Since: 2006
Re: Top Bow rivets
Post by Humblej » Fri Dec 31, 2021 8:44 am
I do not know where to get aluminum rivets, but steel rivets are easy to find, easy to peen by hand, very strong, and better than aluminum rivets in my opinion. You need a tiny little ball peen hammer, like a toy hammer. light taps with the ball end will make quick work of a steel rivet. Back up the head end of the rivet with a solid heavy piece of steel or very large hammer, peen it cold. It is easy and fun, one rivet and you will be an expert.
Re: Top Bow rivets
Post by Original Smith » Fri Dec 31, 2021 11:14 am
I use semi tubular rivets. I believe they are plated steel. As far as I know Ford didn't use solid rivets, at least in 1925!
GG Gregory
First Name: GG
Last Name: Gregory
Re: Top Bow rivets
Post by GG Gregory » Fri Dec 31, 2021 2:16 pm
Original Smith, I didn’t know Ford didn’t use solid rivets…learned something ! I have the solid rivets from Lang’s, I may try to find the semi tubular rivets. If not I’ll try like Humblej advised.
david_dewey
First Name: David
Last Name: Dewey
Re: Top Bow rivets
Post by david_dewey » Fri Dec 31, 2021 2:49 pm
The aluminum rivet will react with both the steel and the wood, I would not recommend going that way!
T'ake care,
David Dewey
Last Name: Juhl
Re: Top Bow rivets
Post by Oldav8tor » Fri Dec 31, 2021 3:15 pm
Aluminum aircraft rivets are normally anodized for corrosion protection. They come in hard and soft versions. I don't know if they would be a good choice in this case as I'm not sure exactly what GG needs rivets for as I have a 1917 Touring whose bows are quite different. Fortunately I have a pneumatic rivet gun from my aircraft building past so am well equipped to set rivets of whatever type. In many cases I'd think alternative fasteners might make sense.
Sheri
First Name: Sheri
Last Name: Cameron
* REQUIRED* Type and Year of Model Ts owned: 1909, 1911, 1915
Re: Top Bow rivets
Post by Sheri » Fri Dec 31, 2021 8:55 pm
Go to your local hardware store and ask for shovel handle rivets. They should have them in a jandorf box somewhere. These work great for felloe plate rivets on early wheels.
