Advertising and Patent Searches
DontKnowMuch
Topic author - Posts: 209
- Last Name: Sanford
- * REQUIRED* Type and Year of Model Ts owned: 14 Touring, 26 Roadster, 27 Roadster
I have a spot light that is shown in the pictures below and am trying to find period ads or patent information on the spotlight. It may be NOS and the only markings shown is "Pathfinder". Because of the way you can rotate the arm and move the light by pulling the handle in and out, it can be moved 360 degrees.
I searched the Forum for information on how to search early magazines for ads. I read somewhere that Google had posted early magazines online but haven't found how to search these magazines. I also looked at Google Patent but had no luck finding this spotlight.
Could someone post how to search for old advertising? Any help finding information on this particular light will be appreciated. Thanks
DontKnowMuch
Re: Advertising and Patent Searches
Still looking for help.
Hap_Tucker
- First Name: Hap
- Last Name: Tucker
James,
Google does have some of the early magazines and books. And they are continuting to add more of them. Below screen shots are from and/or about Google Books:
Below is from
https://www.google.com/books/edition/Mo ... frontcover
Motor West - Volume 37 - Page 56 1922
books.google.com › books
And below is from "American Motorist" Feb 1922 vol 14, pg 15:
The really small print under the illustration reads:
"Here is the very latest in spotlights – the Pathfinder Innercontrol light. It is operated from inside the closed car and has so wide a range of movement that the driver is able to throw the beam directly backward as well as in every other direction without opening the window."
Note there are lots of Pathfinder spotlights as you go into the 1950's etc. but I do not know if they are or are not the same company.
Pathfinder was also the name of an automobile as well as the person who found the path for some of the automobile events. For example the Glidden Tours used a path finder to go ahead of the tour and make sure the roads and bridges were good etc. Below is a photo showing the pathfinder chopping up a large tree trunk that fell across the path. Again Google books; "American Motorist" page 207 Vol 2, 1910:
I hope that is of some help.
Respectfully summitted,
Hap l9l5 cut off
Below is from
Hap l9l5 cut off
Whatever happened to the fellow that could find about any patent a few years back ????? Haven't seem him post in a long, long time !
DontKnowMuch
Hap,
Thanks for the information. I will look on my computer later this morning and will let you know if I have as much success as you did.
Thanks again.
Dennis
Thanks again.
Dennis
DontKnowMuch
Steve,
There was a Canadian member who posted a lot of patent information. I will check with a friend in Calgary about him.
Dennis
Dennis
DontKnowMuch
The person I was thinking of is Art Bell from the Calgary, Alberta area. I have not seen any posts from him in quite a while.
Dennis
Dennis
Another Hays image
- Attachments
- hays p.png (260.15 KiB) Viewed 2720 times
Thank you James - it was Art !
