ignition problem
Philip
First Name: Philip
Last Name: Thompson
* REQUIRED* Type and Year of Model Ts owned: 1924 touring
ignition problem
Post by Philip » Mon Apr 01, 2019 9:31 am
my 24 touring has 4 mid 50s kw coils. i took it out for a spin and had a sudden skip. i found that it ran better on the 6v battery and got home.
switched back to mag. and found that no 4 was not firing switched the coils around and the problem moved so it is a coil problem. i did the
light bulb volt meter magneto test and have good voltage. the coil that is not good has a bigger blue spark at the coil itself than the others.
do i need a new capacitor
why does it work on battery
any advice would be great. philip
Les Schubert
First Name: Les
Last Name: Schubert
Re: ignition problem
Post by Les Schubert » Mon Apr 01, 2019 9:42 am
The blue spark at the points would make me suspect the condenser
KeithG
First Name: Keith
Last Name: Gumbinger
Post by KeithG » Mon Apr 01, 2019 6:39 pm
Philip, Considering that your coils are from the '50's, they probably should be rebuilt with new capacitors & points and properly adjusted for best performance. Coils sometimes fire on battery and not on mag due to improper adjustment. You should also check your timer to see that it's clean and not excessively worn. All the wires and contacts in the coil box should also be shiney clean to make the best contact.
Keith
