If you need help logging in, or have question about how something works, use the Support forum located here
Support Forum
- Last Name: Juhl
Post
by Oldav8tor » Mon Apr 01, 2019 7:38 pm
With the help of a friend I was able to pull the front wheels off my 1917 Touring today. I was pleased to discover that somewhere in the past the ball bearings had been replaced with roller bearings although I was surprised by the different appearance of the two outers (see first photo). The left wheel was reluctant to come off after the outer was removed and when it did the inner bearing came apart and scattered rollers all over the place. There were some tiny burrs on the spindle that were jamming the bearing. I carefully filed the burrs on the spindle and now the other inner slides on and off easily (photo 2). I don't believe the spindle needs to replaced but would appreciate hearing from others.
The races look OK so I think I can get by with a new inner bearing unless there is a reason to replace one of the dissimilar outers.
Other than that, the right kingpin bushings are worn so it looks like I should probably replace both the right and left just to be sure. If I have to take the axle off to take it to where it can be repaired (I don't have a Steven's tool) I was thinking of just unbolting the springs from the frame and taking the whole thing. Anyone have a better idea? My assumption is that if I removed the springs from the shackles on the axle it might be hard to get them back in. Then again, if I decide to replace the shackle bushings they'd have to come off anyway
DickC
- First Name: Dick
- Last Name: Cruickshank
- * REQUIRED* Type and Year of Model Ts owned: 1912 Depot Hack, 1916 Touring
Post
by DickC » Mon Apr 01, 2019 8:37 pm
It looks to me that someone used the old technique to increase the spindle size so the bearing would be snug. The is a popular technique applied to the crankshaft pulley when it is loose. Some take a punch and dent the shaft which raises the surface. I would not think this is a good idea for a front spindle bearing. But what do I know?
Erik Johnson
- First Name: Erik
- Last Name: Johnson
Post
by Erik Johnson » Mon Apr 01, 2019 8:48 pm
"Raspberrying" involves pricking the surface with a hammer and punch to create rough surface, like a raspberry, in order to eliminate slop. It's an old trick that has been used to solve a wide variety of problems.
Unless someone filed flats on the spindle, it is not from 1917. The two flats easy removal of the ball bearing race or the roller bearing from the spindle by tapping them in the back with a drift and hammer.
Post
by RajoRacer » Mon Apr 01, 2019 8:56 pm
We call it "strawberrying" over here ! Somewhere I have a photo of the front of a crankshaft that came into the shop because of a "rod knock" - nope just a loose front fan drive pulley BUT the front of the crank musta had a 100 prick punches !
John.Zibell
- Last Name: Zibell
Post
by John.Zibell » Mon Apr 01, 2019 9:49 pm
I would not recommend using the old outer races. It is best to replace with new bearing and race. The outer race may look good, but the wear on it may not match the angle of the new bearing.
1926 Tudor
Post
by Steve Jelf » Mon Apr 01, 2019 9:56 pm
Removing the shackles from the springs and perches is not difficult.
If you need to replace anything, these are the numbers:
- Bearings, Front Wheel.jpg (37.13 KiB) Viewed 11997 times
- Last Name: Juhl
Post
by Oldav8tor » Mon Apr 01, 2019 9:56 pm
OK - One of the guesses we made about the marks on the spindle was to tighten up the bearing so you're probably right. Question - how tight is the inner bearing supposed to ride on the spindle? If it turns easily (the whole bearing) should it be tightened and is there a way to do that short of replacing the spindle?
Also - I repeat the question.... do you think I need to replace the funny looking outer bearing?
John - if I keep the outer bearings I suspect it would be fine to keep the outer races if they look good.
Oldav8tor on Mon Apr 01, 2019 10:18 pm, edited 1 time in total.
Ruxstel24
- Last Name: Hanlon
Post
by Ruxstel24 » Mon Apr 01, 2019 10:17 pm
Tim, the "funny race" is actually just what's called the cage that's different. It just holds it all together and really doesn't do anything else.
Clean them all good and blow dry (don't spin with air)...then put them against the mating race and turn and feel. If smooth they should be fine. And you should see no pits in the rollers or races.
And no, the whole bearing should not spin on the spindle. I would redo the "raspberrys" and make it a snug/slip fit.
tdumas
- First Name: Ted
- Last Name: Dumas
- * REQUIRED* Type and Year of Model Ts owned: 1927 Coupe, 1924 Touring
Post
by tdumas » Mon Apr 01, 2019 10:38 pm
Replace both inner bearings and cups. They are a standard item available from your local auto or bearing supply and relatively inexpensive.
Erik Johnson
- First Name: Erik
Post
by Erik Johnson » Mon Apr 01, 2019 11:07 pm
Steve Tomaso -
I should have typed "strawberrying." My mind is a little screwed up today.....
Post
by Steve Jelf » Mon Apr 01, 2019 11:43 pm
The best prices on the bearings are usually at Rock auto.
jagiven
- First Name: Jason
- Last Name: Given
- * REQUIRED* Type and Year of Model Ts owned: 26 Roadster, 25/26 speeder
Post
by jagiven » Mon Apr 01, 2019 11:46 pm
Regarding the kingpins, I would replace just the one set of bushings and the kingpin. You can buy a reamer and alignment tool.
First time, I only replace the worn bushings, and I had to redo them few years later. Recently, I replaced both the bushings and the kingpin. The other set still holding strong, with little to no wear.
John.Zibell
- Last Name: Zibell
Post
by John.Zibell » Tue Apr 02, 2019 9:24 am
Just use the bearing in the same race it ran on. As long as you keep the bearings matched you will be good.
1926 Tudor
Post
by RajoRacer » Tue Apr 02, 2019 9:54 am
No worries Erik - I like both !
Ruxstel24
- Last Name: Hanlon
Post
by Ruxstel24 » Tue Apr 02, 2019 10:20 am
I thought this was the "raspberries"
- Last Name: Hjortnaes
Post
by DHort » Tue Apr 02, 2019 11:30 am
Steve Jelf is correct. Go to RockAuto and purchase new races and bearings. Races are cheap and why not have a set of new bearings. This is what you are riding on. How safe would you like to be?
RockAuto does not always have everything in stock. Then contact your local Model T parts dealer and give him some business. Support the men and women that support you.
Post
by Original Smith » Tue Apr 02, 2019 11:57 am
Maybe you don't feel like doing this, but have you considered replacing the spindle? They are easy to find.
- Last Name: Juhl
Post
by Oldav8tor » Tue Apr 02, 2019 8:20 pm
Like the NPR Radio show - "All Things Considered" - I appreciate all your comments. My good friend Brian_D has been advising me and at this point the plan is that I will tag along with him next week when he takes the front axle from a 1915 project to a Model T Guru about an hour and a half from here. The gentlemen has all the tools and the expertise to use them so I'm going to take my axle as well and enlist his assistance in inspecting it and repairing as needed. I'm under a bit of a time crunch if I want to be ready for a tour in mid-May so I think this is a good way to go.
I got most of the axle apart today and decided that I need to replace the kingpins as well as the bushings and also the tie-rod bolts. The threads on the kingpins as well as the tie-rod bolts show some damage which is unfortunate inasmuch as I understand those with "manhole cover" oilers are a prized item. I've attached a photo to show you what I found.
One positive aspect of this whole experience is that I now feel confident to work on the front wheel components - I learn something new every day which is one of the reasons I bought a Model T.
I do have another question - some of the diagrams I've seen from Martin V. of the front wheels shows a "grease chamber" between the inner and outer bearings and grease packed under the cap. When installing the wheels do you pack grease in those areas? Do you fill the cap with grease and turn it on to push grease into the outer bearing and grease chamber like with the grease cups used in other areas?
- Last Name: Juhl
Post
by Oldav8tor » Wed Apr 03, 2019 7:25 pm
The saga continues... I received my new 14120 bearing today. It fits snugly on the spindles so the looseness I reported must have been due to wear on the old bearings. I also noticed that the old 14120 had only 14 rollers compared to 17 on the new so I'm going to get another inner and keep the old one as a spare.
Post
by Steve Jelf » Wed Apr 03, 2019 10:10 pm
Squeeze grease into the bearings and slather on more when you put them in, but no, you don't need to pack the hub cap.
- Last Name: Juhl
Post
by Oldav8tor » Fri Apr 05, 2019 8:44 pm
Here's another question - how often do you pull the front wheels and grease the bearings?
tdumas
- First Name: Ted
- Last Name: Dumas
Post
by tdumas » Fri Apr 05, 2019 8:50 pm
Check your front axle kingpin threads. You may need to helicoil them,
KeithG
- First Name: Keith
- Last Name: Gumbinger
Post
by KeithG » Fri Apr 05, 2019 10:50 pm
Hi Tim, You asked "How often do you pull the wheels and grease the bearings?" I do it at least once a year, depending on how many miles the car is driven. On the T I drive the most, I do it more often and check them frequently.
Keith
John.Zibell
- Last Name: Zibell
Post
by John.Zibell » Sat Apr 06, 2019 8:47 am
tdumas wrote: ↑Fri Apr 05, 2019 8:50 pm
Better yet find someone with a Stevens front axle tool and set it up correctly.
1926 Tudor
- Last Name: Juhl
Post
by Oldav8tor » Sat Apr 06, 2019 11:01 am
I’m taking the axle to a guy with the tools and experience to use them. I believe in doing things right the first time. A friend is getting his axle done at the same time so it’ll be a social event of sorts...We have the helicoils if needed along with new kingpins, tie rod bolts and bushings, etc. I’m looking forward to observing the process and adding to my store of knowledge...for me that is a big part of the fun of owning a Model T
Oldav8tor on Sat Apr 06, 2019 11:11 am, edited 2 times in total.
Post
by Scott_Conger » Sat Apr 06, 2019 11:05 am
Tim
do yourself a really big favor since the axle is out of the car: check for straightness...you may be surprised at what you find
http://www.mtfca.com/discus/messages/17 ... 1323767931
- Last Name: Juhl
Post
by Oldav8tor » Sat Apr 06, 2019 11:13 am
Scott-good suggestion. I’m adding that to the list.
