White Flex Seal for tires
Corey Walker
First Name: Corey
Last Name: Walker
Post by Corey Walker » Sun Jan 30, 2022 11:08 am
I read a thread a few weeks ago about painting tires white with PlastiDip. I thought I might try it but couldn’t find any in white. I bought a can of white Flex Seal and painted a junk tire with it. I tried scrubbing it off with a block of wood and it didn’t come off easily so it should stay on fine for normal driving. I think I may try it out, all my tires are old anyway. I thought this might be another option to create faux white tires.
Re: White Flex Seal for tires
Post by TXGOAT2 » Sun Jan 30, 2022 11:17 am
Applying Flex Seal will provide faster accelleration, higher top speeds, 50% better gas mileage, and will absolutely stop oil leaks, radiator drips, and oil burning! Bridge crumbled? Flood water five feet high and rising? NO PROBLEM! Apply Flex Seal and your car will skim right over water just like a skiff made of old screen doors! Order NOW and we'll double your order AND throw in a nifty trolling motor!
Post by TXGOAT2 » Sun Jan 30, 2022 11:19 am
PS: If that stuff will stick to tires and stay flexible, it might make a good fender liner to prevent paint damage from flying pebbles.
Russ T Fender
First Name: Val
Last Name: Soupios
Post by Russ T Fender » Sun Jan 30, 2022 11:56 am
I used black Flex Seal on the original top of my '22 Centerdoor which was alligatored and no longer waterproof. Looks good and keeps the rain out. Two coats did the job and it seems to hold up well!
Corey Walker
First Name: Corey
Last Name: Walker
Post by Corey Walker » Sun Jan 30, 2022 12:14 pm
I was wrong, it wasn’t Flex Seal, it was this. I just saw it when I went home to feed my dog and cat. Staying with my mom, had hip replacement but I’m going to test it out when I get better. My tires are all old so if it doesn’t hold I need new ones anyway.
Post by John kuehn » Sun Jan 30, 2022 5:10 pm
Another use for flex seal would be to coat 21 “ split rims or 30x3 1/2 rims on the inside.
Clean up the rims pretty good and then coat them. I bet it would work. It’s pretty good stuff.
And don’t laugh till you try it! 🤞
ThreePedalTapDancer
First Name: Ed
Last Name: Martin
Post by ThreePedalTapDancer » Sun Jan 30, 2022 6:30 pm
JohnM
Last Name: Michaelree
Board Member Since: 2010
Post by JohnM » Sun Jan 30, 2022 6:55 pm
It must be good, the screen door in the bottom of my boat hasn't leaked since I put it on. :lol:
jaybee47
First Name: jay
Last Name: bolante
* REQUIRED* Type and Year of Model Ts owned: 1922 Runabout
Post by jaybee47 » Thu Feb 03, 2022 7:37 pm
I tried white Flex Seal liquid on a junk black tire. Pseudo white walls. Used Griot's tire prep and cleaner prior to Flex Seal application. The Flex Seal was brushed on and bonded satisfactorily after it dried. I don't know about its performance in actual riding conditions though. Although it could be good on riding tires, I won't use it because it is too shiny, it displayed brush marks and it has a gloss finish unlike real white walls.
I did use the Flex Seal liquid on the insides of my rims just as an extra precaution to bolster aid for the flaps.
John Heaman
Last Name: Heaman
Post by John Heaman » Thu Feb 03, 2022 8:02 pm
A fellow Model T'er I know lined his flat fenders with 'cut to fit' thin magnetic sheeting, black in color. It worked well and really saved the paint, plus it wasn't visible.
Post by Mark Gregush » Thu Feb 03, 2022 8:20 pm
When I did the top on my 21 huckster, I used a product like Flex Seal on the heavy cotton material I covered it with. After about 8 years it needed a recoat.
