Existing engine info wanted?
Loftbed
First Name: Rod
Last Name: Letcher
* REQUIRED* Type and Year of Model Ts owned: 1915 Speedster
Post by Loftbed » Mon Jan 31, 2022 6:27 pm
I bought this Model T Speedster on Hemmings. It was offered by the Son of the previous owner and he didn't know much about it. The car was originally built by Pete Eastwood in Southern Cal, Pete sold it (minus the engine) to Don Small of Arizona (prior to his passing). Don had the engine built by Larry Blair (AKA Loco Larry) of Santa Fe Springs and had it b///////uilt close to the original engines specs. What I know about it so far is: NOS Sherman head, New Zealand counter balanced crank Model A rods, Custom Ross pistons, Bosch front plate, VW Distributor with special drive, Carter BB1 model 699s carb; Custom Exhaust & Intake, & 12v conversion.
If anyone has further info on this engine, I'd like to know as I am trying to document it.
Rod
:D
1965 Shelby Cobra (Factory Five repo)
1957 Ford Thunderbird
1941 Ford PU
Re: Existing engine info wanted?
Post by speedytinc » Mon Jan 31, 2022 6:49 pm
Larry Blair is still around. He closed his shop in Santa fe springs & opened a smaller shop in Whittier.
Spotted him on the holiday excursion in a T. Sent an email.
Post by TRDxB2 » Tue Feb 01, 2022 1:13 am
Larry Blair info (562) 698-4929
Tin Shed Antique Auto Repair
8949 Santa Fe Springs Rd, Whittier, CA, 90606
Post by Steve Jelf » Tue Feb 01, 2022 1:45 am
When you achieve geriatric status everything reminds you of something else, often something from long ago.
Slauson! :D
https://www.youtube.com/watch?v=y-trLWRvnJY
Loftbed
First Name: Rod
Last Name: Letcher
Post by Loftbed » Wed Feb 02, 2022 1:25 pm
Frank, thanks for the contact info.
I was able to talk to Larry yesterday, and he recalled the engine and how it was built. So I am now able to add more info to the engines 'build sheet". :D :D
Again thank you
Rod
:D
1941 Ford PU
