Flywheel dowel pins
Topic author - Posts: 380
- First Name: Don
- Last Name: Ellis
- * REQUIRED* Type and Year of Model Ts owned: 1911,1917,23,27
Flywheel dowel pins
Is there a certain direction they press out like the triple gear pins?
- Last Name: van Ekeren
Re: Flywheel dowel pins
They only come out one way, tap them out with a drift and hammer, not that tight, from the transmission side.
- First Name: Don
- Last Name: Ellis
Thanks, I started that direction but thought I would ask to be safe.
- First Name: David
- Last Name: Menzies
- Board Member Since: 2012
And they are pressed in from the backside. The fitted area is about .001 larger than the post. Sometimes when they have been removed some material can also be removed and you may need a larger base for a tight fit.
I'm not sure on following you David, the dowels would tap in on the magnet side, to me that would be the front of the fly wheel as it faces the front of the engine.
