Needing a Junk Transmission Drum
dunoon
Topic author - Posts: 133
- Last Name: Davis
- * REQUIRED* Type and Year of Model Ts owned: 1926 coupe
I need a trans drum to use for checking roundness of bands anything will do as long as the drum surface is OK. Tried to find one here where I live but, no luck, let me know what ya have, width doesn't matter. Thanks
Bill Serbst
- First Name: Bill
- Last Name: Serbst
- * REQUIRED* Type and Year of Model Ts owned: 1919 speedster (in progress)
Re: Needing a Junk Transmission Drum
PM has been sent.
Bryant
- First Name: Bryant
- Last Name: Shafer
Interesting the subject came up as I was just watching a model t tips video on transmission band relining. The guy in the video was using a axle brake drum to check roundness. Iam assuming it was a small drum axle but I don’t know the diameter. Maybe someone here knows?
- First Name: Dennis
- Last Name: Seth
Why not just cut a disc out of plywood to the size of the drum you need to set roundness
