Chicago Aux. Trans.
Topic author - Posts: 2036
- First Name: craig
- Last Name: leach
Chicago Aux. Trans.
Hi Guys,
A freind just picked up a Chicago Aux. trans is the pocket (center of main shaft beraing ) like a Warford made out of unobtainium or is it a standard type bearing that is available? Thanks.
Carig.`
Carig.`
Dropacent
- Last Name: Morsher
Re: Chicago Aux. Trans.
Craig, I was up to my elbows in them a couple years ago here. ( thanks mike !). There are at least two different types, one appears to be pretty common bearings and the other was a real wild style, something prehistoric looking. They WERE NOT interchangeable, and I had enough of the good modern looking ones to complete my mission. I forget now if the cases were interchangeable. Hope this helps a little.
- First Name: craig
- Last Name: leach
Tim,
The way my luck goes this will be a jarasic park one. I forgot to ask what the length is on them are they the same as a warford? This may turn out to be one of those I should have said gee I cant even spell model T things.
dang.1922
- Last Name: Greger
I have 2 Chicago transmissions and the cases are different. The input shaft bearing bore is larger on one. Both use the same bearing in the center. Bearings were still available last fall, and I think that bearing is the same as the cluster gear bearings. Dan
Michael Peternell
- First Name: Michael
- Last Name: Peternell
- * REQUIRED* Type and Year of Model Ts owned: TT gas truck, T tractor conversions, '15 touring, '17 speedster, '26 16 valve speedster
If I remember right the case's with patent pending on them had the oddball bearings.
walber
- First Name: Walt
- Last Name: Berdan
- * REQUIRED* Type and Year of Model Ts owned: '18 Speedster had 25 touring and 26 coupe
Side request - does anyone happen to have a spare input shaft for a Chicago? I really like the transmission but the square part of the shaft the goes into the 4th main is beat up giving excess lash in the driveline.
- First Name: craig
- Last Name: leach
Thanks Guys,
Looks like it will be on the bench soon.
