Working on idea for different approch to magneto coils
Post by Mark Gregush » Tue Feb 15, 2022 12:45 am
Has anyone thought about or tried coating the strip with insulating varnish, then wind and wrap? Then after assembling, coating the whole thing with the varnish and baking?
jab35
Last Name: Bartsch
Re: Working on idea for different approch to magneto coils
Post by jab35 » Tue Feb 15, 2022 10:43 am
I've thought about it enough to decide never to try it. I feel this would require perfect quality control meaning perfect coverage with a uniform coat of electrical varnish and a way to dry the copper strips before winding the coils. Not saying it cannot be done, but just one point of metal to metal contact could impair function of the individual coil or worse, compromise the mag ring circuit. Mag ring rebuilding isn't rocket science, but can become tedious because to have a good result the insulation needs to be perfect. (And as others here have mentioned, the tedium of mag ring rebuilding is much less than the tedium of removing and replacing a failed mag ring in the engine. YMMV, jb
Les Schubert
First Name: Les
Last Name: Schubert
Post by Les Schubert » Tue Feb 15, 2022 11:13 am
Many years ago I rebuilt a mag coil using insulated copper coil wire and then gave it a good coating or two of Glyptal. It is still in service.
Les Schubert
First Name: Les
Last Name: Schubert
Post by Les Schubert » Tue Feb 15, 2022 11:16 am
As a teenager I used to make power transformers for old battery radios so they could be plugged in! I’ve continued to play with stuff like that. So I have experience.
Post by Allan » Tue Feb 15, 2022 5:21 pm
Les, your wire winding is what I thought would be a better /quicker way to achieve the same result, but I had no idea if enough wire could be wound in the same space to work in the same manner. I had visions of insulated spools being wound with wire, the spools being pressed onto the mag ring poles, and a heavy insulating dip used to bake it all together.
Les Schubert
First Name: Les
Last Name: Schubert
Post by Les Schubert » Tue Feb 15, 2022 7:26 pm
Glyptal is a special insulating varnish that has been used for years for this application. I see it is listed online today. I probably used 14 gauge wire and probably stacked it 2 or 3 windings wide and the same number of turns as original. The car starts easily on mag and hand crank!
Art M
First Name: Art
Last Name: Mirtes
Post by Art M » Tue Feb 15, 2022 9:27 pm
Les,
Have you ever tried to rewind a generator armature, is so with success. Hyatt used to rewind their on motors. I should have paid attention. The retired worker died about a year ago, after I contacted him but before I met with him.
Art Mirtes
Les Schubert
First Name: Les
Last Name: Schubert
Post by Les Schubert » Tue Feb 15, 2022 9:48 pm
I have not needed to rewind a armature. I have resoldered the commutator.
ABoer
First Name: Anthonie
Last Name: Boer
* REQUIRED* Type and Year of Model Ts owned: 1912 touring 1923 roadster 1925 pickup
Post by ABoer » Wed Feb 16, 2022 5:32 am
I read somewhere that there is NEW insulated 3/16 strip for seal .
Do one of you know something about that ???
Toon
ABoer
Last Name: Boer
Post by ABoer » Wed Feb 16, 2022 10:51 am
I made a mistake !!!!
for seal must be for sale .
Toon
Last Name: Hatch
Post by Dan Hatch » Wed Feb 16, 2022 2:39 pm
RV had the wire. He had a special run made many years ago.
I have rewound generator armatures, it is not hard work. Just very time consuming and tedious. After winding the armatures are dipped and baked. A Lejay manual will tell you more than you want to know about winding.
Art M
First Name: Art
Last Name: Mirtes
Post by Art M » Wed Feb 16, 2022 3:01 pm
Dan,
Thanks for the info on rewinding armature. I have two generators. One good one and one that got fried when a diode failed. Just thinking of trying to rewinding one, as I am always trying to expand my experience and knowledge. $200. For a rewound armature. That sounds reasonable considering all.
Art Mirtes
Dropacent
Last Name: Morsher
Post by Dropacent » Wed Feb 16, 2022 3:06 pm
Art, it’s a whole lot easier to come by and grab one off the shelf. I’ve got a growler here, too, to check the armatures.
