Hinges on 1913 vs 1914 Windshield
BRENT in 10-uh-C
First Name: Brent
Last Name: Terry
* REQUIRED* Type and Year of Model Ts owned: 1909 Tourabout, 1914 Runabout, 1914 Touring, 1916 Speedster, 1925 Speedster, 1926 Hack
Post by BRENT in 10-uh-C » Fri Feb 18, 2022 12:39 pm
Are the hinges interchangeable on a 1913 vs 1914 Frames? In other words, if I needed a Windshield for a 1914 but I have a 1913 Windshield, can I use the forward folding Windshield for the time being and then change-out the hinges to make it fold rearward when those are located without any other modifications to the existing Windshield Frame??
TIA
Les Schubert
First Name: Les
Last Name: Schubert
Re: Hinges on 1913 vs 1914 Windshield
Post by Les Schubert » Fri Feb 18, 2022 12:58 pm
The vertical support arms are also different. The 14 ones are bent out so that the windshield can fold down. I have a 13 RHD Canadian touring car.
Erik Johnson
First Name: Erik
Last Name: Johnson
Post by Erik Johnson » Fri Feb 18, 2022 1:56 pm
Good, 1913 windshields are not as plentiful as 1914 windshields and, in my opinion, are worth considerably more than 1914 windshields.
Taking the above into consideration, I would not alter a 1913 windshield. I would use it as a placeholder on the car until a good, 1914 windshield is found.
Also, for the 1913 model year, there four different brands of windshields were utilized so there were differences in design among brands, especially the hinges.
For 1914, only one brand of windshield was utilized so the design was uniform from car to car.
BRENT in 10-uh-C
First Name: Brent
Last Name: Terry
Post by BRENT in 10-uh-C » Fri Feb 18, 2022 6:15 pm
Thank you.
Post by Original Smith » Sat Feb 19, 2022 9:12 am
1913 windshields fold forward. 1914 windshields fold backwards. Go figure!
Last Name: Hatch
Post by Dan Hatch » Sat Feb 19, 2022 10:46 am
There are some in swap meet trailer. Will be at Luray if you are not coming to Chickasha. Dan
