Fender rivet size?
Fender rivet size?
Post by Steve Jelf » Tue Mar 01, 2022 11:27 am
I suspect this is one of those parts that's the same for all years, but the particular car in question is a 1915. What size are the rivets that hold the brackets to the fenders? I need to remove the brackets to repair some fender cracks, and will need to install new rivets.
Re: Fender rivet size?
Post by TRDxB2 » Tue Mar 01, 2022 11:53 am
Difference due to quantities and/or sizes ?
Don D
First Name: Don
Last Name: Demio
* REQUIRED* Type and Year of Model Ts owned: 1919 T
Post by Don D » Tue Mar 01, 2022 12:11 pm
Another source:
Big Flats Rivet Co.
Jim Dix
PO Box 100
Big Flats, NY 14814
Phone: (607) 562-3501
Email: jdix6@stny.rr.com
Best of luck,
Dom
Post by Steve Jelf » Tue Mar 01, 2022 1:18 pm
A lot of the rivets in Jim's catalogue are listed only by size. He does specify ¼ x ¾ brazier head for front fenders, but I don't see anything listed for rear. That's why I asked about size. I'll ask him.
Lang's catalogue shows a ? for 13-16.
If Jim doesn't have them long enough for the rear, I'll ask Mister Google.
Post by TRDxB2 » Tue Mar 01, 2022 1:32 pm
Snyder's says truss head! Looked in Lang's offerings again. Used a different heading for 1913-16. Truss or oval. that is the question :?
Post by Steve Jelf » Tue Mar 01, 2022 2:58 pm
One online source says truss and brazier are synonyms. I suppose I can get truss heads, and if the heads are too big I can turn them down in the lathe to match the originals.
Post by TRDxB2 » Tue Mar 01, 2022 3:57 pm
I had been looking at rivets, entirely different application., and yes came across the same definitions truss= brazier. This site gives all dimensions (head sizes been the one of interest crown & diameter) for oval & truss https://prairierivet.com/products/solid-rivets/ doubt if the buck needs to care
Post by speedytinc » Tue Mar 01, 2022 3:58 pm
The question you are not getting answered is what is the "correct" head diameter & profile, diameter & length. Outside of measuring your original rivets(less paint build up), I dont have the answer. Maybe this comment will steer others to your needed answer.
Post by RajoRacer » Wed Mar 02, 2022 11:54 am
How many you needing Steve ? I believe I have some left that Otis Clinton machined back in the 60's & 70's from original Ford NOS parts.
