1914 Ford Model T Roadster
Craig E. Luton
First Name: Craig
Last Name: Luton
* REQUIRED* Type and Year of Model Ts owned: 1914 Ford Runabout; 1915 Ford Touring; 1936 Ford Pick-up
Post by Craig E. Luton » Sat Mar 05, 2022 8:48 pm
Does the turtle deck on a 14 Ford roadster have a sheet metal panel fit inside the turtle deck that coves the opening between the turtle deck and body?
Thank you, Craig
Re: 1914 Ford Model T Roadster
Post by Wayne Sheldon » Sat Mar 05, 2022 10:06 pm
I know the 1915 does. I believe the 1914 does as well.
Craig E. Luton
First Name: Craig
Last Name: Luton
Post by Craig E. Luton » Sat Mar 05, 2022 11:19 pm
Thank you, Craig
Last Name: House
Post by George House » Sun Mar 06, 2022 8:23 am
Yes. They do and my ‘14 runabout does 😁
Post by John kuehn » Sun Mar 06, 2022 8:33 am
14 thru mid 22 Roadsters had the sheet metal back in the turtle decks. The change came in early 23 models. Somebody on the forum probably knows for sure.
sweet23
First Name: Darryl
Last Name: Bobzin
Post by sweet23 » Sun Mar 06, 2022 10:29 am
Here are some photos of an early trunk deck I have. hope they help. Darryl
Post by Original Smith » Sun Mar 06, 2022 10:43 am
My '13 runabout has a sheet metal panel that starts at the tack strip on the back of the body and goes all the way to the rear sill. All one piece.
Craig E. Luton
First Name: Craig
Last Name: Luton
Post by Craig E. Luton » Sun Mar 06, 2022 11:50 am
Thank you everybody, you all have been a big help.
Craig
Post by Rich Eagle » Sun Mar 06, 2022 12:00 pm
Darryl, thanks so much for posting those photos. Many turtles are found with all that removed making it hard to know what was there.
Post by Wayne Sheldon » Sun Mar 06, 2022 6:29 pm
The originals were spot welded into place at the top and sides. Nailed of course on the bottom. I tack-brazed mine I made into place since I don't have a spot welder.
Turtle decks as with bodies were produced by several companies. They varied somewhat in details and materials from one manufacturer to another. I can see some variations between the one Darryl B posted photos of and mine, also one I borrowed from a good friend to copy that front panel from to replace my missing panel.
Also, a lot of these turtle deck/trunks had a wooden floor as shown in the photos. A few originals I have seen did not have that floor, nor any sign that it ever did, just the wooden framework around the outer sides and front. Bolted down, the body's rear deck is the only floor in the trunk.
