License Plate
dunoon
Topic author - Posts: 133
- Last Name: Davis
- * REQUIRED* Type and Year of Model Ts owned: 1926 coupe
License Plate
I just acquired a 1926 Va plate in good condition, just surface rust. I want to get it restored. Does anyone know who can restore plates? Thanks
- Last Name: House
Re: License Plate
Google: mtfca license plate restoration
Brent Mize
- First Name: Brent
- Last Name: Mize
- * REQUIRED* Type and Year of Model Ts owned: 1927 Sport Touring & 1927 Sport Runabout
Re: License Plate
Brian Mabry.
He does beautiful work.
https://finishyourplates.com/
I’ve had several sets done and they are perfect.
MWalker
- First Name: Mike
- Last Name: Walker
Re: License Plate
Lee Lawson in Arkansas has done several for me, and lots of other folks. He also does repair if they need it. His work is impeccable. leelawson1374@att.net
Rich in Colorado
- Last Name: Carlson
- * REQUIRED* Type and Year of Model Ts owned: 1922 Center Door 1923 Touring
Re: License Plate
Looks like you have options. Here is who I use.
Before:
After:
Larry Scott:
That was $95 plus shipping. I sand blast the plates before I send them to him. He is in Denver, but I think he does all states.
Good Luck!
Before:
After:
Larry Scott:
Good Luck!
Rich in Colorado
1922 Model T Center Door
1923 Model T Touring
1928 Model A Tudor
1956 Ford Thunderbird
1966 Ford F250 Camper Special
1928 Model A Tudor
cslandry
- First Name: Chris
- Last Name: Landry
- * REQUIRED* Type and Year of Model Ts owned: 1915 Speedster, 1926 Touring, 1923 Depot Hack project
- Board Member Since: 2013
Re: License Plate
Apparently some states won't let you use refinished plates, even if they exactly match the original colors. I haven't done it, but I often thought the solution to that was to get approval for the plates first (if needed), then have them refinished. I think the chances of being stopped for having nice clean plates is pretty minimal.
Re: License Plate
Yes, at least one state says you may not use a restored plate. Another state says it must be restored. In either case, how do they know whether it's restored or NOS?
John Codman
- Last Name: Codman
Re: License Plate
Massachusetts does not allow a year-of-manufacture plate to be restored, but prior to my moving south I had seen several YOM plates that were obviously restored. I have never heard a story about either a cop or a state vehicle inspector being enough of an AH to say anything about it. Here in Florida the process is to visit the local tax collector's office (they handle registrations) to have the number cleared. This is usually not a problem because Model T era plates use a different numbering system. You then have the plate restored and send it to the DMV in Tallahassee to have the restoration approved. They then return the plate with your registration and an expiration sticker that is the same as the ones that they give to modern vehicle registrations. I didn't want it on my plate so I made an aluminum "topper" that uses the top right license plate bolt. I put the sticker on that and so far in five and a half years, nobody has said anything about it.
mbowen
- First Name: Miles
- Last Name: Bowen
Re: License Plate
Got a quote from Brian today for $395 plus $15 s/h to restore my two 1925 Michigan plates. I’m going to pass for now. The state has approved them for use as is, so that’s what I’m going to do.Brent Mize wrote: ↑Mon Mar 07, 2022 6:54 pmBrian Mabry.
Miles
1924 Touring “Bonnie”
1925 Express Wagon “Clyde”
Sarikatime
- Last Name: Seress
Re: License Plate
If your state does not allow yom plates, buy personalized plates with the same numbers and or letters as the restored yom plates and now you are legal. If ever stopped, just pull out the modern plate with the same numbers and letters from under the seat. There is more than one way to skin a cat.
varmint
- First Name: Vernon
- Last Name: Worley
Re: License Plate
https://www.dmv.virginia.gov/vehicles/antique.html
If you are providing vintage license plates, then the year embossed on the license plate must match the model year of the vehicle. In addition, DMV must inspect and approve the physical condition of the vintage plates.
To register your vehicle with antique or permanent vintage license plates, DMV charges a one-time $50 registration fee.
Vern (Vieux Carre)
