Sandblasting Masks
Flivver
First Name: Steven
Last Name: Park
* REQUIRED* Type and Year of Model Ts owned: 1926 runabout
Sandblasting Masks
Post by Flivver » Sun Mar 20, 2022 11:16 am
Going to sandblast a front axle, and wanted to protect some of the surfaces. Will try 3D-printed caps and plugs.
Click for 'video'
Click for 'video'
mbowen
First Name: Miles
Last Name: Bowen
Re: Sandblasting Masks
Post by mbowen » Sun Mar 20, 2022 9:59 pm
You might try removing the perches from the axle. I’ve rebuilt the axles on both of my T’s and all four perches were a slip fit in the axle. I’m guessing your perches are rusted in place?
Miles
1924 Touring “Bonnie”
1925 Express Wagon “Clyde”
Post by Steve Jelf » Sun Mar 20, 2022 10:13 pm
The masking magic words: Gorilla Tape.
Post by Allan » Mon Mar 21, 2022 6:33 am
I can understand masking up new bushes that were fitted prior to sand blasting, but that's not the usual order in which I do things. In a used axle I have yet to find shackle bushes which did not need replacing.
Flivver
First Name: Steven
Last Name: Park
Post by Flivver » Mon Mar 21, 2022 5:19 pm
The masks survived blasting, and worked well.
Post by Allan » Tue Mar 22, 2022 5:08 am
I have no idea how such a printer works, what skills are needed to operate it, how long the process takes,nor how much materials cost. However, the same results can be achieved in an old tech way. Leave your old spindle bolts just threaded through the lower eye, leave the nuts on the perch mountings and leave an old shackle in each perch. This might even be quicker, and you get a pair of clean perch nuts as a bonus.
