FS- New Rocky Mtn. 6 Speed Countershaft
Dan McEachern
First Name: DAN
Last Name: MCEACHERN
Post by Dan McEachern » Sun Apr 07, 2019 12:03 am
For Sale- new countershaft for Rocky Mountain 6 speed auxiliary transmission. I had to make one for a transmission I'm working on so I made an extra.
These are chrome-nickel steel carburized and ground to size. If you have a Rocky Mountain transmission, these shafts are usually worn. $145.00 plus shipping. PM or dmcgearsatyahoodotcom. I can also deliver to Bakersfield swap meet. thanks, Dan
Rick_Rice
First Name: Rick
Last Name: Rice
* REQUIRED* Type and Year of Model Ts owned: 1925 TT Closed Cab Express
Re: FS- New Rocky Mtn. 6 Speed Countershaft
Post by Rick_Rice » Sun Apr 07, 2019 10:41 am
Hi Dan,
I sent you a PM.
Kind Regards,
Rick Rice
Dan McEachern
First Name: DAN
Post by Dan McEachern » Sun Apr 07, 2019 12:25 pm
Rick- I have replied to your PM. Dan
jburns79se
Last Name: Burns
* REQUIRED* Type and Year of Model Ts owned: 1912 speedster
Post by jburns79se » Tue Apr 09, 2019 1:38 pm
Dan,please call 409-962-2643 if still available or if your source could produce two more. Number is home phone with recorder if I am not home.
Dan McEachern
First Name: DAN
Post by Dan McEachern » Tue Apr 09, 2019 3:09 pm
James- I'm the source of the shafts. I can make more, but they would need to wait until I have a load of parts going to heat treat unless someone wanted to pay the freight to heat treat just a few shafts. I made these because I had a transmission that needed a new shaft, and I did not want to sell it with a worn shaft. I'll have the transmission at Bakersfield for sale. I'll try to call you or you can e-mail me at dmcgearsatyahoo.com
Rick_Rice
First Name: Rick
Last Name: Rice
Post by Rick_Rice » Wed Apr 10, 2019 3:43 am
Hi Dan,
To confirm, sent your check out two days ago for the shaft. Please confirm when you have received it.
Kind Regards,
Rick Rice
Dan McEachern
First Name: DAN
Post by Dan McEachern » Mon Nov 21, 2022 2:31 pm
bump- I have two of these left on the shelf.
Post by Scott_Conger » Mon Nov 21, 2022 3:24 pm
Dan, it's a great service that you have provided with these shafts. Thanks for all you do for our hobby.
