1917 Serial Numbers Daily List
Doug 845
First Name: Doug
Last Name: Murphy
Post by Doug 845 » Wed Mar 23, 2022 9:09 am
Is there a daily list of serial numbers used in September 1917.
Re: 1917 Serial Numbers Daily List
Post by Steve Jelf » Wed Mar 23, 2022 10:55 am
Yes. It's in Bruce McCalley's Model T Encyclopedia. If you don't have it I can look up the number for you.
Doug 845
First Name: Doug
Last Name: Murphy
Post by Doug 845 » Wed Mar 23, 2022 11:19 am
I don't have the encyclopedia. Can you please tell me what day in Sept. of 1917 that serial number 2217841 was used?
Thank you
jab35
Last Name: Bartsch
Post by jab35 » Wed Mar 23, 2022 11:30 am
There is a reference here to a book, 'Model T Ford' By Bruce McCalley containing daily production by serial #, suggesting 150+ pages needed to record the information. Monthly production is here, I Don't have the current version of MTF Encylopaedia, best, jb
https://www.fordmodelt.net/downloads/mo ... umbers.pdf
Doug 845
First Name: Doug
Last Name: Murphy
Post by Doug 845 » Wed Mar 23, 2022 11:44 am
James,
Thanks for the reply, but I was trying to find the exact day that my serial number was stamped. The block casting date says 9/22/17. I always thought that there normally is a couple weeks or a month between the serial number and the casting date. Mine appears to be a couple days possibly.
richc
First Name: Rich
Last Name: Chillingworth
* REQUIRED* Type and Year of Model Ts owned: 1924 C-Cab TT
Post by richc » Wed Mar 23, 2022 12:12 pm
Your serial number 2,217,841 shows the assembly date is Sept 25, 1917. I have the digital version of the Encyclopedia on my PC and find it a very valuable resource.
Regards,
Rich C.
Doug 845
First Name: Doug
Last Name: Murphy
Post by Doug 845 » Wed Mar 23, 2022 12:25 pm
Thank you very much Rich. My engine was assembled and stamped 3 days after the casting date.
richc
First Name: Rich
Post by richc » Wed Mar 23, 2022 1:27 pm
The short timing between the cast date and assembly is very typical for 1917. Same day and next day examples are common as well for that year. The foundry must have been having a hard time keeping up with the production line.
Rich C.
Post by Steve Jelf » Wed Mar 23, 2022 2:00 pm
I'll go beyond the date of Tuesday, September 25, 1917 (1918 model year) and guess second shift (early afternoon). Of course that assumes a steady pace of production through all three shifts. :)
Last Name: Juhl
Post by Oldav8tor » Wed Mar 23, 2022 3:03 pm
My engine casting date is September 18th, 1916 and assembly date was September 23rd, 1916. They didn't waste much time.
