Best upgrade yet, better everything
BobP
Last Name: Peterson
* REQUIRED* Type and Year of Model Ts owned: Original 1911 open runabout, 1914 tr, 1916 rdts, 1921 tr, 1923 rdst, 1925 cp. 1927 pu, 1927 tr.
Post by BobP » Fri Mar 25, 2022 7:02 pm
Better than a high compression head, better than a warford, better than almost anything. Apex carburetor throttle, (pneumatic butterfly) 25%-50% more miles to gallon, easier starting, more power on hills, more power on heavy pulls, less carbon in your motor, reduced oil consumption, reduced repair bills, more pep in a sprint, quicker getaway. Fits kingston and Holly carbs with 1 inch carb. Why don't they still make them? It would be a very inexpensive option.
Re: Best upgrade yet, better everything
Post by Allan » Fri Mar 25, 2022 7:08 pm
If you fit a longer shaft to accommodate a second device on the other end, would that give 50-100% savings?
Post by TXGOAT2 » Fri Mar 25, 2022 9:36 pm
These incredible miracle devices would be available to all at no additional cost except for the fact that agents of Big Oil bought them all up and dumped them into the sea in a secret location and then they locked up the prominent European Scientist who discovered the secret molecular realignment principles that cause ordinary low-test gas to release the kind of blazing power previously available only to daring aircraft test pilots using special Army Air Corps fuel!
Post by TXGOAT2 » Fri Mar 25, 2022 9:43 pm
Beat the pump pirates! Put new, thermoplastic translucent clothespins on your fuel line!!! Power robbing motor sludge and gritty carbon deposts are blasted away as you enjoy faster accelleration, higher top speeds, and 35 to 50% improvement in gas mileage using any old cheap gas! Supplies are limited, so ORDER NOW before the Big Oil Pump Pirates force us to take down this special commercial message!
MWalker
Last Name: Walker
Post by MWalker » Sat Mar 26, 2022 9:40 am
If you believe all that Apex spiel, I can make you a heckuva deal on some oceanfront property in Arkansas. :D
Post by TXGOAT2 » Sat Mar 26, 2022 9:52 am
Caution! Adding three or more of the devices can cause your gas tank to overflow on long trips!
otrcman
First Name: Dick
Last Name: Fischer
Post by otrcman » Sat Mar 26, 2022 10:18 am
The bad news is that if all cars used these fantastic gas saving devices, gas stations would have to become dumping stations. Every few hundred miles you would have to stop to drain out all the excess fuel. The dumping stations would charge by the gallon to drain your tank. To meet EPA disposal standards, the stations would charge $5 per gallon to haul it away.
Dick
dobro1956
First Name: Donnie
Last Name: Brown
Post by dobro1956 » Sat Mar 26, 2022 10:57 am
M Walkers post is a scam. I own all the ocean front property in Arkansas. Contact me for the best rates ....,
MichaelPawelek
First Name: Michael
Last Name: Pawelek
Post by MichaelPawelek » Sat Mar 26, 2022 5:11 pm
I personally liked the throttle plate that would lock closed so no one could steal your Model T!
Art M
First Name: Art
Last Name: Mirtes
Post by Art M » Sat Mar 26, 2022 5:43 pm
I had one on my car and found it isn't compatible with MMO
Art Mirtes
OilyBill
First Name: William
Last Name: May
Post by OilyBill » Sun Mar 27, 2022 2:40 pm
Harumph!! You kids today!
I put THREE of those on, and now I don't even fill up my gas tank! It stays full all the time.
Also, this thing STOPS all the rattles, my transmission shifts much better, and I have a totally free neutral! Additionally, when I use my lights, the battery NEVER goes down, even though I have gas lights!
On top of all that, my front steering shimmy is gone, my rear axle whine is now just a hum, my seats are much more comfy, and my windshield NEVER gets dirty!
AND, I noticed that all my brass has become self-polishing! Why, I don't lift a finger before a tour! I just go inside and watch Gilligan's Island re-runs, and when I come back out, the car is gleaming!
My teeth are whiter, too!
This is the best $2 I EVER SPENT!
Post by TXGOAT2 » Sun Mar 27, 2022 3:14 pm
This scientifically-correct device will also house-train any dog of any age... even a wild dingo! Absolutelyy ends "accidents" and eliminates "doggy odor"! Removes mothers-in-law from guest rooms and elimates those pesky wallpaper stains!
ironhorse
First Name: G.R.
Last Name: Cheshire
Post by ironhorse » Mon Mar 28, 2022 7:37 am
Yes but will it evict slimy non-paying tenants from your rental property?
Post by TXGOAT2 » Mon Mar 28, 2022 8:28 am
Evicting squatters is illegal!
jiminbartow
Last Name: Patrick
Post by jiminbartow » Tue Mar 29, 2022 11:59 am
I was going to post that I have had one of these on my T for 50 years and except for the fact it is adjustable and positions the throttle connection 1/4” higher and a little longer, it makes no difference whatsoever. After I read several responses I realized it was not a serious thread, endorsing a miracle accessory that does nothing that it claims. Only what the original one does. I guess the mechanical equivalent of snake oil patent medicine claims. Jim Patrick
jab35
Last Name: Bartsch
Post by jab35 » Thu Mar 31, 2022 9:51 am
Hopefully the OP makes it into the Accessory of the Day archives on this forum. Love that and all the serious technical discussion that followed!
tdump
First Name: Mack
Last Name: Cole
Post by tdump » Fri Apr 01, 2022 8:48 pm
Reminds me of all the "You can save up to 40% by switching to our car insurance" commercials.
It is made to appear that I could get insurance with company A, then later switch to company B and then later to C and before you know I would be getting PAID to have car insurance! :lol:
Post by Norman Kling » Fri Apr 01, 2022 9:19 pm
I wonder how it works with a water injector? You should use STP in the crankcase and Marvel Mystery oil in the gas and a water injector on the intake manifold. With those three and the special throttle, you could become a source of high price gas for sale to others! :lol:
Post by TXGOAT2 » Fri Apr 01, 2022 9:34 pm
STP is good stuff, but Bardahl is great on mashed potatoes.
John Codman
Last Name: Codman
Post by John Codman » Sat Apr 02, 2022 12:25 pm
I remember the "mini supercharger" That had rotating blades and bolted between the carburetor and the intake manifold. It gave you much more power and better gas mileage!
