A/C and or other auxiliary brakes?
Angmar
Last Name: Bailey
Post by Angmar » Thu Mar 31, 2022 10:08 pm
Is there still a source(s) for a complete setup for the A/C and or other auxiliary brakes besides the Rocky Mountain version?
Thanks in advance.
Still crankin old iron
Re: A/C and or other auxiliary brakes?
Post by Steve Jelf » Thu Mar 31, 2022 10:17 pm
Yes. Larry Sidmore: (209) 533-9207. See his ad n the VF. He supplies the brakes and the pedal, and can refer you to the source for the linkage.
Angmar
Last Name: Bailey
Post by Angmar » Thu Mar 31, 2022 10:19 pm
Thanks. I will give him a call. I must have overlooked his ad in the latest VF.
Post by Norman Kling » Fri Apr 01, 2022 11:49 am
Depends on which AC brakes you are looking for. I have a set on a 26 which says AC on the parts, but is identical to the Rocky Mountain on my other 26. The AC set was purchased about 1990 I think from Chaffin's and the later ones about 2005 from the Rocky Mountain brake co in Temecula.
Angmar
Last Name: Bailey
Post by Angmar » Fri Apr 01, 2022 1:12 pm
I spoke with Larry, apparently his units do not come with the rods and other related parts to make the set up work. Anybody making those parts? Hi source is no longer available. Are both setups for the large drum or?
thanks
