1914 Brass Holley carb onto a 1923 engine
jaybee47
First Name: jay
Last Name: bolante
* REQUIRED* Type and Year of Model Ts owned: 1922 Runabout
Post by jaybee47 » Tue Apr 05, 2022 9:50 pm
Any thoughts and advice of any potential problems or benefits with this arrangement?
jaybee47
First Name: jay
Last Name: bolante
Re: 1914 Brass Holley carb onto a 1923 engine
Post by jaybee47 » Tue Apr 05, 2022 9:52 pm
Forgot to include a picture
Holley Brass 1914 Carburetor.jpg (28.39 KiB) Viewed 1854 times
Post by speedytinc » Tue Apr 05, 2022 9:56 pm
Its a fine carb. May even mix the fuel better than the correct NH. The only disadvantage is it flows less CFM compared to the NH. You might not notice under 50-55 mph. Its easier to get the fuel level perfect. The little copper pickup tube can give fits if split or not in the exact position.
Post by Steve Jelf » Tue Apr 05, 2022 10:32 pm
They sure do clean up pretty. :)
jaybee47
First Name: jay
Last Name: bolante
Post by jaybee47 » Wed Apr 06, 2022 9:41 am
Very nice carb Steve. That is the appearance that I am striving for. I'll have the tire rims brass plated too. Am putting together a 'fake' 1911 Runabout and will install as many brass/bronze parts as I can gather, substitute or make. Not a factory correct match but...what the heck...it will be what it will be... :D :D 8-) 8-)
MWalker
Last Name: Walker
Post by MWalker » Wed Apr 06, 2022 10:05 am
That carb has no provision for an in-cab choke. If your car has an electric starter, that would be inconvenient. Later G's had an additional arm on the choke lever for that. You could swap out the choke for a later one if need be. If you always use the Armstrong starter when the engine's cold, then it's no problem.
