Pouring Babbitt using a Hempy cooper jig
Topic author - Posts: 157
- First Name: Randall
- Last Name: Strickland
- First Name: Harry
- Last Name: Lillo
- * REQUIRED* Type and Year of Model Ts owned: Speedsters, racers, depot hack, coupe
Re: Pouring Babbitt using a Hempy cooper jig
Thank you for sharing this Randall.
Can you help me understand the purpose of spraying the jig with what
I assume was water after pouring the babbitt?
Harry Lillo
Harry Lillo
It is fun to see that after hearing about it for years.
- First Name: DAN
- Last Name: MCEACHERN
He is not spraying the jig if you look closely, he is spraying the main web under the fixture to cool the block and chill the babbitt.
- First Name: CHARLIE
- Last Name: BRANCA
- Board Member Since: 2010
Explain the peening please.
"peening or compressing the babbitt by hammering is often specified.... to compress the babbitt in a bearing and harden it so that it will give better service."
https://www.911metallurgist.com/babbitted-bearings/
- First Name: Erik
- Last Name: Barrett
- * REQUIRED* Type and Year of Model Ts owned: 1913 speedster 1924 touring 1925 dump truck
When I pour these I pour from both sides using left and right hand ladles. The quicker you fill the mold the less chance of a cold shut. The water is sprayed to chill the babbitt as quickly as possible which preserves the quality of the metal. I have a helper ready with the squirt bottle handy. If there is a leak in the setup often it can be chilled with water and the pour salvaged. My molds are patterned after KR Wilson tooling but I use a smaller mandrel to give more room to bore for undersized cranks.
I under cut my KRW arbor for pouring and have tried pouring with the block vertical. That seemed to work ok. Some people chill some don't.
- Last Name: Hatch
To quote someone famous on here. “If you don’t peen the Babbitt, the crankshaft will do it for you.”
That will result in a loose bearing. Dan
