Hudson Hogshead for Fords
Tadpole
First Name: Tad
Last Name: Glahn
Post by Tadpole » Fri Apr 15, 2022 2:33 pm
Found this interesting photo of an accessory made by Hudson Motor Specialties of Philadelphia, sure makes lining replacement look easy.
(Photo taken from the Library of Philly archives)
Last Name: Hatch
Re: Hudson Hogshead for Fords
Post by Dan Hatch » Fri Apr 15, 2022 2:51 pm
I have heard that hard to stop from leaking too. Dan
Post by Wayne Sheldon » Fri Apr 15, 2022 6:01 pm
Wasn't that marketed as the "Hudco"?
I have seen a few of them over the years.
Post by TRDxB2 » Fri Apr 15, 2022 6:21 pm
Here is a link about it and more pictures http://www.mtfca.com/discus/messages/80257/116389.html
Post by John kuehn » Fri Apr 15, 2022 7:22 pm
Has any one seen one of there covers actually on T over the years? Kinda of neat if they would work. With the improvements in sealant’s over the years maybe leaking wouldn’t be a big issue.
Post by Allan » Fri Apr 15, 2022 7:43 pm
I wonder what the purpose was for the large plug next to the magneto pickup.
Tim Rogers
Last Name: Rogers
Post by Tim Rogers » Fri Apr 15, 2022 8:11 pm
You can service the back of the horn while you're at it...
Post by RajoRacer » Fri Apr 15, 2022 8:17 pm
The large plug was the access port for cleaning out the oil funnel. Hudson also made a nice set of c.c. repair arms ! And yes, they were called Hudco Covers.
I have one on my parts shelf - figured next time I pull the engine on the Centerdoor I'll install it - ever attempted a band change in a Centerdoor ? Not for the faint of heart !
Post by John kuehn » Fri Apr 15, 2022 8:56 pm
I would think when these were made you would buy the cover and add your existing pedals and parts to the Hudson cover. But that’s a guess. I haven’t seen one over the years but I wasent looking for one either. Probably don’t show up to often if at all.
Post by Allan » Fri Apr 15, 2022 9:15 pm
That makes good sense Steve. Interestingly, the fitted on in the initial post does not have it. It is an early starter car with the squared off tin can bendix cover, so perhaps the good idea came later.
Farmer J
Last Name: Kramer
* REQUIRED* Type and Year of Model Ts owned: 3
Post by Farmer J » Sat Apr 16, 2022 7:52 pm
Steve Ellis donated one to the MTFCA Museum this spring. Looked like it would make changing bands a snap but sealing it up would be impossible.
SurfCityGene
First Name: Gene
Last Name: Carrothers
Post by SurfCityGene » Sat Apr 16, 2022 8:11 pm
Farmer J, You must not have ever used Ultra Black? That'd be the perfect sealant, tough and flexible with super adhesion. I've toyed with the idea of converting one of my alum HH's since I've found them fairly easy to weld on? There is even less room for changing the bands on those.
1912 Torpedo Roadster
Jack Putnam, in Ohio
First Name: Jack
Last Name: Putnam
Post by Jack Putnam, in Ohio » Sat Apr 16, 2022 10:30 pm
I had one, put it on a TT for looks as I never had to change the kevlar bands. Sealing was not a problem as I used the felt from the band changing kit that I coated with silicone. Never leaked. Before modern sealants I'm sure it was a problem.
