Parking Brake Pawl Replacement
CatGuy
Last Name: Hunt
* REQUIRED* Type and Year of Model Ts owned: '26 Runabout
Post by CatGuy » Mon Apr 18, 2022 8:11 am
Do I need special tools to replace this? A blacksmith? Just hammer the pin flat?
Emeraude
Last Name: Loranger
* REQUIRED* Type and Year of Model Ts owned: 1921 touring
Re: Parking Brake Pawl Replacement
Post by Emeraude » Mon Apr 18, 2022 9:27 am
I just replaced mine. I ground off the head of the rivet then drilled it out. I used a an bolt and lock nut rather than trying to re rivet.
Ken Buhler
First Name: Ken
Last Name: Buhler
Board Member Since: 2012
Post by Ken Buhler » Mon Apr 18, 2022 10:00 am
Are the new ones made of hardened steel? I got some years ago that were made soft material so I mig welded the tip of mine and ground it sharp. If the rivet is not worn, that is a lot less work.
Work honestly
Stay true to your word
Get the job done right
Post by Allan » Tue Apr 19, 2022 5:55 am
The pin is stepped. The diameter is greater within the pawl. The smaller end goes through the lever and the protruding end is easy to peen over. Not at all difficult to do with a hammer and a buck.
CatGuy
Last Name: Hunt
Post by CatGuy » Tue Apr 19, 2022 2:40 pm
I tried at lunch to hammer/drive that pin out, but no luck. Does it need drilled out instead?
Post by speedytinc » Tue Apr 19, 2022 2:44 pm
Grind the peened end flush with the lever. Support & tap out with a pin punch.
Post by Jerry VanOoteghem » Tue Apr 19, 2022 3:03 pm
Just as John says, but maybe with more than just a "tap".
Post by Allan » Tue Apr 19, 2022 10:18 pm
It doesn't hurt to drill part way through the pin, to the depth of the handle That way you have a locator for the pin punch. If it still wont move, step up the drill size until it almost breaks out the side of the pin. The belt the pin punch on what remains in the pawl.
