windshield end caps?
bobt
Last Name: Thompson
* REQUIRED* Type and Year of Model Ts owned: 1915 touring 1926 roadster
Post by bobt » Thu Apr 21, 2022 6:19 am
can someone please tell me what holds the windshield end caps on? should i apply heat? 1915 touring. bobt
First Name: Henry
Last Name: Lee
Re: windshield end caps?
Post by Henry K. Lee » Thu Apr 21, 2022 6:24 am
A picture would help but normally a slotted machine screw. With age and rust behind it you may need to use a hardwood block against it after removal of the screw of coarse working it off equally with a mallet.
Hope this Helps,
First Name: Henry
Last Name: Lee
Post by Henry K. Lee » Thu Apr 21, 2022 6:28 am
If you are replacing glass, to get a grip on the glass, use about 3" to 4" c clamps with thin wood blocks and pieces of rubber against the glass on both sides works well. Just wiggle equally while holding firm on the frame normally will get the worst ones out.
Last Name: House
Post by George House » Thu Apr 21, 2022 9:18 am
Don’t apply heat. With an ice pick clean out the rust in the screw slot. Then insert a flat tip screwdriver in the slot. Now tap the top of the screwdriver to ‘shock’ the rusty screw in the filler block. Pressing down hard on the screwdriver try and back out the screw. If it ain’t working soak the screw in PB Blaster. Keep trying. When screw removed use hard wood block as described above to remove end caps...🇺🇦
D Stroud
First Name: David
Last Name: Stroud
Board Member Since: 2011
Post by D Stroud » Sun Apr 24, 2022 7:24 am
As George said, 'shock' the screws. After shocking the screws a few times with a standard screwdriver, use an impact screwdriver, IF you have a bit that fits the screw well. A tapered bit, which most screwdrivers have, will just try to 'slide' out of the screw slot while turning it. An impact screwdriver will also shock the screws while turning them in or out, IF the bit has parallel sides, NO taper. Just don't get in a big hurry, give some time for the penetrating oil to work. Also, as said, with the impact screwdriver, try screwing them in and out a few times, don't hit it too hard, let the lube work into the threads. Did I say, don't get in a big hurry? Don't get in a big hurry, let the lube work. :) :) :) JMHO. Dave
1925 mostly original coupe.
