Wiring for dash light socket
jiminbartow
Last Name: Patrick
Post by jiminbartow » Thu Apr 21, 2022 12:07 pm
What would be the best location on the instrument panel to locate the dash light? It has the switch on the socket so requires constant juice. There is a battery location on the switch and a battery location on the ammeter. Which would be best? Jim Patrick
Re: Wiring for dash light socket
Post by Jerry VanOoteghem » Thu Apr 21, 2022 12:12 pm
The battery location on the switch and the left side ammeter terminal are essentially the same thing. Pick the one that is less "crowded" by other wires, etc.
The "battery" terminal on the ammeter will work too. It's just that when you run the dash light, it will show a tiny discharge indication on the ammeter. Really, I think "battery" is the wrong name for the yellow wire, since it actually goes to the generator.
jiminbartow
Last Name: Patrick
Post by jiminbartow » Thu Apr 21, 2022 3:50 pm
Thank you, Jerry. I used the battery connection on the switch. Jim Patrick
