engine knock
wilfbrad
engine knock
Post by wilfbrad » Tue Apr 09, 2019 4:59 pm
1915 T, getting knock when engine cold, just at thrust and drag power setting and after engine gets hot, no knock.. Is this a sign of center main bearing??
Wilf
Russ T Fender
First Name: Val
Last Name: Soupios
Re: engine knock
Post by Russ T Fender » Wed Apr 10, 2019 11:57 am
Sounds like it might be a wrist pin. Does the knock get softer or go away when you retard the spark while the engine is still cold?
Shane Lach
First Name: Shane
Last Name: Lach
Re: engine knock
Post by Shane Lach » Wed Apr 10, 2019 12:01 pm
Piston slap potentially.
Ruxstel24
Last Name: Hanlon
Re: engine knock
Post by Ruxstel24 » Wed Apr 10, 2019 12:14 pm
I'm with Shane.
Do you know if the pistons are iron or aluminum ?
Most anything else will not quiet up when warm.
Adam
First Name: Adam
Last Name: Doleshal
Re: engine knock
Post by Adam » Wed Apr 10, 2019 3:17 pm
Sounds like the typical noise you start to get from aluminum pistons when clearance gets to be a bit too wide (generally over .006”). If you drive for an hour on a 70-80 degree day and the sound gradually becomes unnoticeable, that’s probably the issue. If that is the issue; it won’t hurt anything and likely won’t get much worse very fast as long as there is no contamination in your engine, you change your oil regularly, and don’t drive much over 30. You might be able to get several years off it depending on how much you drive. Knurling the existing pistons or boring & honing the block to the next oversize with new pistons and rings are the only 2 fixes.
