At long last, the biggest little swap meet in Virginia is officially less than TWO WEEKS AWAY!
It’s finally May and time for LURAY!
Looking at the long-range daily forecast, the weathermen are promising 76 degrees and partly sunny… perfect weather here in the valley for both days. And with that, I must say that this will be the last advertising blast until the event.
So get a hotel room, or sleep in your truck if you have to. Either way, you’re not going to want to miss this. See the attached flyer for information or log on to www.mapwsm.com for further information. We will see you there on the 13th and 14th!
Less than Two weeks until LURAY!!!
James_Lyons-WV
Topic author - Posts: 199
- Last Name: Lyons
- * REQUIRED* Type and Year of Model Ts owned: 1913 Touring, 1915 Touring, 1925 Coupe
