Spiral wound rear axle roller bearings F/S
Layden Butler
First Name: Layden
Last Name: Butler
Post by Layden Butler » Sun May 01, 2022 4:41 pm
USED rear car axle spiral wound roller bearings part # 2508, these are for both inner and outer and left and right side, lightly used very good condition and measure .002" wear or less on the rollers, no loose cages, limited number available, most have no makers markings but some say Hyatt and a few Ford, all are the original style spiral wound rollers and probably date from the 1920s, they have been cleaned in solvent but you should clean again to get any residual out of the inside of the rollers, price is $75 each, domestic postage is a flat $15 per order regardless of number ordered.
Layden Butler
First Name: Layden
Last Name: Butler
Re: Spiral wound rear axle roller bearings F/S
Post by Layden Butler » Sat May 21, 2022 2:13 pm
Happy purchasers to date! Limited number still available and then they will be gone.
Last Name: Strange
Post by CudaMan » Sat May 21, 2022 3:59 pm
I have what I need of these, but many don't - Thank you for making these available, sure hope that those that need them take advantage. :)
Layden Butler
First Name: Layden
Last Name: Butler
Post by Layden Butler » Sat Jun 04, 2022 1:07 pm
Maybe last call for these before they are gone!
David Tipton
First Name: David
Last Name: Tipton
Post by David Tipton » Sat Jun 04, 2022 1:24 pm
Layden,
Just set you an email.
Dave Tipton
Layden Butler
First Name: Layden
Last Name: Butler
Post by Layden Butler » Sat Aug 13, 2022 8:11 pm
One more time around!
Layden Butler
First Name: Layden
Last Name: Butler
Post by Layden Butler » Tue Feb 07, 2023 9:25 pm
This may be the last time offered!
None have ever been returned!!
MarkS
Last Name: Sumner
* REQUIRED* Type and Year of Model Ts owned: 1915 Ford Model T Touring
Post by MarkS » Wed Feb 08, 2023 1:11 am
Email sent
