Intake manifolds all the same?
Dropacent
Last Name: Morsher
Post by Dropacent » Fri May 06, 2022 1:31 pm
Not so quick. One of the most plentiful old T parts on the planet. I can’t give them away along with a 5$ bill. I’ve gone to making wind chimes out of them. These common stock intakes range from 1 5/16 ID to 1 1/8” ID. Engine Joe gave me the big un for my latest project. Don’t pitch them before you measure them!
Don
First Name: Don
Last Name: Azevedo
* REQUIRED* Type and Year of Model Ts owned: 5
Board Member Since: 2003
Re: Intake manifolds all the same?
Post by Don » Fri May 06, 2022 4:20 pm
I have 14 cast iron intake manifolds with different numbers or letters on the front. Does anyone know if these numbers and letters correspond to any particular year?The ones I have are: 3, 4, 7, 9, D, E, G, H, M, N, O, S, V and nothing. Surely O.S. has the answer.
Don
IMG_20220506_124432.pdf
(3.89 MiB) Downloaded 125 times
Ed Fuller
First Name: Ed
Last Name: Fuller
Board Member Since: 2012
Post by Ed Fuller » Fri May 06, 2022 5:03 pm
Hey Tim!
How about posting a picture of your manifold wind chimes?
Would love to see it!
Post by Mark Gregush » Fri May 06, 2022 10:25 pm
I went through the pile I had hopping to find that holy grail, the cast iron made at the switch from aluminum to cast iron or any that looked a little different inside. So far, mine were just run of the mill average. ;)
Don D
First Name: Don
Last Name: Demio
* REQUIRED* Type and Year of Model Ts owned: 1919 T
Post by Don D » Sat May 07, 2022 3:15 am
Tim,
What is the cast letter or number on the 1 5/16" intake manifold if it has one on it? I too have several buried in my shop.
Thanks,
Dom
Aussie16
First Name: Warwick
Last Name: Landy
Post by Aussie16 » Sat May 07, 2022 4:09 am
I have a box full as well! Will be sure to measure them before I make a wind chime. Can we see a picture of the wind chime? Sounds like a good way to repurpose a part That I will never be able to get rid of!
Joe Bell
First Name: Joe
Last Name: Bell
Post by Joe Bell » Sat May 07, 2022 7:46 am
Mark, I came across the Holy Grail and have one on the shelf, it is the only one I have ever come across.
Joe Bell
First Name: Joe
Last Name: Bell
Post by Joe Bell » Sat May 07, 2022 10:18 am
casting number A T 512 B 4 just had to find it and look it up, wish I knew how to post a picture? Old school!
Post by Original Smith » Sat May 07, 2022 10:26 am
Does anyone have information when the 1914 style manifold actually came out. I understand around the time the new 1914 bodies were introduced?
How long were they produced? Perhaps into the 1915 model year?
Cordes_jeff
First Name: jeff
Last Name: cordes
* REQUIRED* Type and Year of Model Ts owned: 25
Post by Cordes_jeff » Sat May 07, 2022 10:50 am
I have approximately 4 cast iron high volume intakes. They are scarce and so rewarding when you find one in a pile for 5$.
Post by Mark Gregush » Sat May 07, 2022 10:55 am
For Joe Bell, transition cast iron intake.
Dropacent
Last Name: Morsher
Post by Dropacent » Sat May 07, 2022 11:20 am
The last wind chime sold from my daughter store. I’ll get another assembled when I get a couple free minutes.
Joe Bell
First Name: Joe
Last Name: Bell
Post by Joe Bell » Sat May 07, 2022 4:28 pm
Thanks Mark for posting it.
