Thoughts on using Seafoam
Topic author - Posts: 831
- First Name: Austin
- Last Name: Farmer
Does anyone use Seafoam in their T or TT? We use it in our 1925 Touring and 1923 TT Firetruck. What do you all think of Seafoam for a T? We use it on each tank.
- Last Name: Wrenn
Re: Thoughts on using Seafoam
It's an excellent product. Smooths out many an engine. Will help clean your carb. Trouble is its expensive adding to an already over priced gallon of gas. Never thought I'd see the day it would cost as much as $30+ to fill up a model T!!
Les Schubert
- First Name: Les
- Last Name: Schubert
Sea foam has saved me a number of carb rebuild jobs!!
John Heaman
- Last Name: Heaman
- * REQUIRED* Type and Year of Model Ts owned: Canadian 1912 Ford Model T Touring
It's my go to additive.
I’m reading a book about anti-gravity. I just can’t put it down.
Mikey1968
- First Name: Michael
- Last Name: Jewell
After 40 years working on cars for a hobby ... and necessity, I finally began using it. Works great on the small engines like on lawn mowers, etc. I have 9 cars and a handful of mowers, tillers, tractors and atvs. I can't possibly make it to each engine and routinely run them so Sea Foam to the rescue. Good example.....this winter needed to fire up the snow blower....nope! Poured in a little Sea Foam in the tank and wait a bit. VROOOM! First pull!
- First Name: Adrian
- Last Name: Whiteman
Ohh!!! Its been MANY years since we had low prices like under $40 a tank....Never thought I'd see the day it would cost as much as $30+ to fill up a model T!!
Gas as cheap as the prices you complain about would be a dream come true for us.
Tmooreheadf
- First Name: Tom
- Last Name: Moorehead
I’ve used sea foam in modern cars religiously. Get over 300,000 miles on all cars with never a valve or injector issue. I do it every oil change and those oil changes are geared to what the dash board says, not a standard mileage reading. Some oil changes are at 15,000 mile. I attribute a lot of those good numbers to sea foam in the fuel.
I also use it in the fuel for the model T’s every oil change about 500 miles. One can in a full tank of fuel. I can get it here at Rural King for $6.99 a can.
Good stuff for small engines and mixed in with two cycle fuel, about 4 oz to 2 gallons plus the two cycle oil.
