Spindle bushing thrust cutter question
Stephen_heatherly
Topic author - Posts: 391
- First Name: Stephen
- Last Name: Heatherly
Does anyone know where I can get a face cutter like the one used with the spindle bushing thrust cutting tool sold by the vendors? I'm looking for one to build a set up for cleaning up the thrust surfaces on the axle yoke.
Stephen
Stephen
- Last Name: Hatch
Re: Spindle bushing thrust cutter question
I use a small piloted counterbore.
I use math & cut them in a lathe before installing new bushings in the spindle.
Stephen_heatherly
Dan, where did you order the counter bore? Do you have pictures showing your method?
Thank you,
Stephen
Thank you,
Stephen
- Last Name: House
Stephen,...I don’t have the specific face cutting tool you requested but I have an original spindle bushing face cutting tool used by mechanics of the era - that I’d loan you. I’ve used it for decades with great success. BTW, I only face the lower brass bushings because the T s entire front weight is on the upper brass bushings so I leave it full thickness.
- Last Name: Hatch
He is facing the axle yoke, NOT the spindle bushings.
I will post a picture later of my set up. May start producing it. Dan
Stephen_heatherly
