Confusing Model T terminology
2nighthawks
Topic author - Posts: 407
- First Name: Harold
- Last Name: Schwendeman
The recent topic titled "Adjusting The Clutch Band" brings to mind an interesting point,...the fact that old automotive "parts terminology" can sometime cause confusion. As an example, back in the Model T era, what we nowadays call a tappet, or valve lifter, or cam follower, was, back in the day ( and still in Model T parts catalogs) is called a "PUSHROD"! I'm quite sure that almost nobody of todays automotive "community", whether Model T folks or modern "gearheads" would think of anything but long, skinny soda straw-shaped rods of the valve train of the modern overhead valve type automobile engines,...just a thought,....harold
Re: Confusing Model T terminology
Guess terminology is still “floating” as a valve does.
To me the T engine is L head or side valve so thick ‘lifters’ are used directly to move the valve stems up.
Other valve train designs like overhead valve set ups use pencil like ‘pushrods’ to move the rockers arms to send the valves down.
But maybe blame Henry for the confusion. This is page from 1913 Model Owners manual!
I think some Ford literature referrred to the engine block as "the cylinder".
Was it Henry who called the bonnet the hood and the hood the top?
I believe those terms originated with foreign agents! Those sinister operatives would conceal accumulators beneath the floorboards, and were known to replace the proper Ford wrenches with spanners. Some even attached sumps to unsuspecting customers' cars.
John Codman
- Last Name: Codman
And of course, the gas lever was known as the "acceleratrix" and the brake was known as the "deceleratrix". The clutch pedal, of course, was the "velocitator".
Okay... I made those up myself...
Chris Barker
- First Name: Chris
- Last Name: Barker
A cotter pin is a tapered pin with a nut on the thin end used to fix a lever on a shaft - most commonly on older bicycle pedals.
We stop nuts unscrewing with split pins, but only after tightening them with a spanner.
Somerset
England
Somerset
England
