Use your Ford !!
Rich P. Bingham
Topic author - Posts: 1808
- First Name: Rich
- Last Name: Bingham
Use your Ford !!
I've seen a few setups to use a T for powering other machinery, but this is the first I've seen to use the crank ratchet. Would be handier for cars with a self-starter, though.
Get a horse !
jiminbartow
- Last Name: Patrick
Re: Use your Ford !!
I think the crank would have to be removed and a shaft, equipped with a reverse ratchet inserted into the crank hole. Jim Patrick
Someday, if I live long enough, I'll make one of those belt drives that sets under the back wheels.
Rich P. Bingham
- First Name: Rich
Oh yes ! Most certainly. The ad mentions a governor. I wonder what that entailed ?jiminbartow wrote: ↑Sat May 28, 2022 10:05 pmI think the crank would have to be removed and a shaft, equipped with a reverse ratchet inserted into the crank hole. Jim Patrick
Get a horse !
It's so interesting to see these innovations. Here are a couple more.
http://www.mtfca.com/discus/messages/41 ... 1419719308
http://www.mtfca.com/discus/messages/179374/250365.html
