Whatizit? Brass top ignition coil.
Matt in California
First Name: Matt
Last Name: G
* REQUIRED* Type and Year of Model Ts owned: 1926 Touring, 1926 Fordor Project, TT C-cab flatbed farm field find, TT dump truck project
Post by Matt in California » Sun May 29, 2022 6:42 pm
Here is a unique quail that I found. It appears to be a Ford coil but does not have the two brass connections on the side. Instead it has a screw on the bottom and some sort of spring connection on the side.
I look forward to hearing your responses.
Matt
MichaelPawelek
First Name: Michael
Last Name: Pawelek
Re: Whatizit? Brass top ignition coil.
Post by MichaelPawelek » Sun May 29, 2022 7:05 pm
Modified for a single cylinder engine?
Galen West
First Name: Galen
Last Name: West
* REQUIRED* Type and Year of Model Ts owned: 14 touring, 06 model N, 15 roadster, 18 centerdoor, 22 coupe, 23 chassis, 25 touring, 26 cut off, 26 coupe
Post by Galen West » Sun May 29, 2022 7:19 pm
Hi Matt, Would you be interested in selling your coil? Thank you, Galen West 541 five four zero 2 five nine six
Last Name: van Ekeren
Post by Kerry » Sun May 29, 2022 7:22 pm
The induction coil wasn't unique to Ford, it was used on many other ignition systems of cars and stationary engines at that time.
Post by Wayne Sheldon » Sun May 29, 2022 7:59 pm
The brass top is "very similar" to the typical late 1913 and 1914 style brass top coils (1915s and 1916s had four top screws as opposed to six) that Ford used. However, even there, I think I see a couple discrepancies. Coupled with the wooden body variations (which someone could have altered?), I agree with others that it was likely made for some other application. All the companies (except maybe later Ford themselves?) that made coils for Ford also manufactured and sold coils for other applications! These would include stationary engines as well as many other industrial or transportation uses (including boat motors).
It should be noted that as much as it may look like a Ford coil on the outside? The inside may not be anywhere near Ford specifications or quality! I opened one up years ago and was amazed by how undersize the electrical inside was.
Basically, it is a great conversation piece!
Most people that have one of those "other applications"? Have been using Ford coils as replacements for years already.
Poppie
First Name: Neil
Last Name: Martin
* REQUIRED* Type and Year of Model Ts owned: 11 tourer 18 tourer 18 TT
Post by Poppie » Mon May 30, 2022 6:57 am
isn't that coil a master vibrator coil? ...n
Ron Patterson
Post by Ron Patterson » Mon May 30, 2022 7:50 am
KW Master Vibrator coil.
Has a low inductance primary winding and no secondary winding.
Ron Patterson
Matt in California
First Name: Matt
Last Name: G
Post by Matt in California » Mon May 30, 2022 7:32 pm
Thanks so much! A master vibrator makes since with only two connections.
Poppie
First Name: Neil
Last Name: Martin
Post by Poppie » Mon May 30, 2022 7:59 pm
To the top of the class Ron P.
As Matt from Cal described the coil box, it has only two contact terminals, would say Bat/mag live terminal(screw) and load terminal(coil box side ) and as there is no third terminal, I would say that there is no High tension coil inside the said coil box consequently the reason for my previously posted reply. Master vibrator coil....n
