Safety wire?
Topic author - Posts: 1486
- First Name: Keith
- Last Name: Townsend
Safety wire?
Since these are drilled, are they supposed to be safety wired together?
Jack Putnam, in Ohio
- First Name: Jack
- Last Name: Putnam
Re: Safety wire?
Yes. If wired they won't come out for sure.
OilyBill
- First Name: William
- Last Name: May
Re: Safety wire?
Wiring them would be a good idea. They have the holes. Adding the safety wire certainly won't hurt anything. Check and see if someone in your club has a set of safety wire pliers. Most airplane mechanics have a set you could probably borrow for the 1 minute it takes to put safety wire in. I still have 2 sets of them in my toolbox from my work on airplanes.
Re: Safety wire?
They just need to be stopped from winding out, so all you need is a wire between them to stop this. Maintaining tension with aircraft type twitching is overkill for this application.
Re: Safety wire?
It's good to have things wired in, especially things which could get into the crankcase and wreck you magneto or starter ring.
Re: Safety wire?
Check your clearances with the bolt heads & clutch fingers. This area is real tight.
Re: Safety wire?
I believe 1912 is the last year they did that.
Re: Safety wire?
I had a 13 customer that had it also. Thats why I mention a caution about clearance checking.
