Howdy All, can anyone state unequivocally the type machine screws for the inside door latches and square panel (into the D nuts). Thank you
george
TT Enclosed Cab Machine Screw Question
Topic author - Posts: 2997
- Last Name: House
- Last Name: House
Re: TT Enclosed Cab Machine Screw Question
...does anyone know?....
One390
- * REQUIRED* Type and Year of Model Ts owned: 25 TT
George, I have a steel cab tt and can take it apart to describe/dimension the machine screws, but I am not clear on what latch you have if yours is in a wood cab. I cannot unequivocally answer your question, but maybe someone will chime in if you can clarify the latch with a picture. Hope this will help get an answer. TS
- Last Name: House
Thank you Tim. I should’ve stated it’s a Ford TT steel cab. I’ve taken the rusty latches off by having to drill them and freed up the mechanisms. I see there’s 4 countersunk slotted screws per latch. What size? Then I’ve acquired 2 of the interior square door panels. What size screws there? I’ll also need to acquire the correct size taps.. thanks in advance!
- Last Name: House
...does anyone else feel theres a much smaller audience viewing this Forum than the previous iterations? I like this design much better but I often see me an a few other named hobbiests and 9-14 guests listed at the bottom
