Rear spring install
John L
Last Name: Leffler
* REQUIRED* Type and Year of Model Ts owned: 1923 Coupe, 1927 Touring
Rear spring install
Post by John L » Sun Jul 10, 2022 7:28 pm
Is there a certain tightening sequence to tighten up the rear spring assembly? My 23 T coupe always tighten up more to the left side then the right. Which make the car lean to the left.
Last Name: Tannehill
Re: Rear spring install
Post by JTT3 » Sun Jul 10, 2022 7:48 pm
John have you taken the rear spring off recently? If not you may do that to check a few things.
Check for broken leafs, especially the very top short spring
Check the spring pad, is it worn & intact
Check the head of the spring center bolt to be sure it’s centered in the rear frame wing, that it is still proud in the square hole or if the head of the bolt is worn thin.
Last Name: Hjortnaes
Post by DHort » Sun Jul 10, 2022 11:58 pm
Like John says,
1. Check to make certain ,bolt is correctly placed.
2. Make sure the shackles are also in the right place and not off a little to one side or the other.
pron022020
First Name: Tyler
Last Name: Prondzinski
Post by pron022020 » Mon Jul 11, 2022 10:36 am
Equally tighten the U bolts. I have found that some cars just aren't perfect.
