Seen on T bay
Seen on T bay
Post by Original Smith » Thu Jul 14, 2022 10:49 am
There appears to be a mint 1913 KW coil box switch on ebay now, that is on a master vibrator. They are identical to the one used on the 1913 KW coilbox. All you need to do is put your correct plate on it. I have used these often. They are asking $100.
First Name: Keith
Last Name: Townsend
Re: Seen on T bay
Post by KWTownsend » Fri Jul 15, 2022 1:36 am
I see two of them. (One is starting at $145) And they both have the Corbin brass plated "lunch box" style latches.
