Rear Hub Puller
CatGuy
Last Name: Hunt
* REQUIRED* Type and Year of Model Ts owned: '26 Runabout
Rear Hub Puller
Post by CatGuy » Mon Jul 18, 2022 10:21 am
I don't think I asked this before. At least I can't see that I did. In pulling the rear hub on my '26 Runabout with wire wheels, do I need to buy the threaded hub puller that is in the catalog or can I use a 3 finger style like the parts stores has?
Kevin Pharis
First Name: Kevin
Last Name: Pharis
Re: Rear Hub Puller
Post by Kevin Pharis » Mon Jul 18, 2022 11:52 am
A 3 finger should work fine... as long as it is the type that bolts on with the lug nuts and designed for pulling hubs. An original would have slid into the reduced diameter portion at the end of the hub snout. The threaded pullers are for the wood wheel hubs, but could be the right tool for the job if your car has wood wheel hubs with wire wheel adapters.
Are your hubs threaded...?
CatGuy
Last Name: Hunt
Re: Rear Hub Puller
Post by CatGuy » Mon Jul 18, 2022 11:58 am
I'll have to see if they are threaded. I can't recall just yet. I hadn't heard that the threaded pullers were for wood wheel hubs.
jsaylor
Last Name: Saylor
Re: Rear Hub Puller
Post by jsaylor » Mon Jul 18, 2022 12:05 pm
You can buy this pitman arm puller from Harbor freight for $16.00. with a little grinding it makes an excellent puller for the wire wheel hub.
Re: Rear Hub Puller
Post by Steve Jelf » Mon Jul 18, 2022 12:51 pm
You can buy this pitman arm puller from Harbor freight...
Does it fit the Model T pitman arm?
jsaylor
Last Name: Saylor
Re: Rear Hub Puller
Post by jsaylor » Mon Jul 18, 2022 2:53 pm
Unfortunately it does not fit the Model T pitman arm. It's too wide.
Flivver
First Name: Steven
Last Name: Park
* REQUIRED* Type and Year of Model Ts owned: 1926 runabout
Re: Rear Hub Puller
Post by Flivver » Mon Jul 18, 2022 5:52 pm
Yep, it works great!
