Rajo head
Topic author - Posts: 1649
- First Name: Darel
- Last Name: Leipold
Rajo head
I have a rajo head I found 50 years ago. How do I tell what model? 4 or 8 valve? Have the manifold, but not tthe cover.
Re: Rajo head
Post a photo if you can - they have several different port configurations - 4 valve is just that - 4 valves in the head & uses the stock exhaust valves in the block - 8 valve is 8 valves in the head.
- First Name: Darel
Re: Rajo head
Thank you, I will check that out.
- First Name: Kevin
- Last Name: Pharis
Re: Rajo head
If it weighs 80+ pounds... it’s an 8 valve. Pictures obviously will help, but a simple count of ports and note what side of the head they’re on will yield a solid answer. Also measure the combustion chamber depth and count the spark plugs while yur in there
- Last Name: Meixner
Re: Rajo head
If you bring it to NLNB I can look at it.
- First Name: Darel
Re: Rajo head
it is an 8 valve head. looks good, adoes not seem to be rusty and is in good condition. The manifold is rusty, but should clean up okay. Do not havwe the cover. What model is it?
- First Name: Darel
Re: Rajo head
What and were and when is The NLNB?
- First Name: Darel
Re: Rajo head
I should have known. New London, New Brighton. I might be at New Brightopn on Saturday.
Re: Rajo head
I found some photos. The top 2 show the difference between the 8 and 4 valves. The 2 at left were called Model Cs but I don't think both are. Someone will be able to tell you more.
http://www.mtfca.com/discus/messages/41 ... 1408509225
This thread has some good info including the last post by Mark Chaffin describing different models.http://www.mtfca.com/discus/messages/41 ... 1408509225
- Last Name: Hjortnaes
Re: Rajo head
NLNB, New London to New Brighton car run. America's version of the London to Brighton car run in England. Only cars built 1908 and earlier are allowed to participate. Wednesday to Friday are practice runs, and you can purchase lunch and dinner in advance. The Saturday run is 120 miles from New London to New Brighton. Rob likes to be first in the big K.
www.antiquecarrun.org
- First Name: Darel
Re: Rajo head
does someone have a photo of the manifold for an 8 valve head. The one I have is an all in one.
Re: Rajo head
If all the ports are on the same side, it's not a B or BB.
- First Name: Darel
Re: Rajo head
It seems to be a model 30. I am probably wrong that the manifold is an all in one. Will check this evening.
- First Name: Kevin
- Last Name: Matthiesen
Re: Rajo head
The later Rajo Model 30 manifold is all in one, four exhaust and one intake port on the right side. The above Model 30 picture from early Rajo advertising shows a early type head with a different manifold .
- First Name: Darel
Re: Rajo head
Thank you. I will check this evening and take some photos.
- First Name: Darel
Re: Rajo head
It is a model 30. The manifold is similar to the illustrated one, but the intake manifold (Atached) is plain. I will post some photos.
- First Name: Erik
- Last Name: Barrett
- * REQUIRED* Type and Year of Model Ts owned: 1913 speedster 1924 touring 1925 dump truck
Re: Rajo head
The model 30 is the lower performance end of the 8 valve Rajo lineup. They were commonly used on trucks, often called the commercial Rajo. While not as fast as the hotter heads, it will definitely boost performance and look just as cool on a model T as the others.
- First Name: Darel
Re: Rajo head
Here are some photos. The head is in better condition that the photos show. the chambers are clean, the manifold is rusty, bt should clean up. I have the rest of the parts in a box (no rust on them). I have had this head for 60 years. I amy sell it, but I want to determine value. If I did sell i t, I would use the $$ for a new set of wheels for my 1910 touring. I have the correct hubs.
Re: Rajo head
Up on the shelf I have one of these that was modified. The cross over intake lump opposite the manifolds side has been machined for 2 carb mounts on either side of it. Quite the butchery of an original head, but sure to increase the head's performance. Smart thinking to bring the performance up on a commercial head.
- First Name: Darel
Re: Rajo head
Doing the Elsworth Wis. swap meet this Sunday. After that I will take some time and clean up the head and manifold . I will get out the box of the rest of parts and photo all together.
- First Name: Darel
Re: Rajo head
Wonderful nice day at Elsworth swap meet. Good sized crowd of friendly people. Sold lots of nice items. Good early Ford parts are not common at general swap meets any more. I brought nice items, so they sold well.
- First Name: DAN
- Last Name: MCEACHERN
Re: Rajo head
Nice that the intake manifold extension is still on the manifold.. Most of those got lost along the way.
- First Name: Darel
Re: Rajo head
I plan on putting it up for sale. I would rather have it picked up than ship. Is any one interested?
