Free: Steel Truss Head Rivets 3/16" x 1 1/4"
Rodger Erickson
Topic author - Posts: 481
- First Name: Rodger
- Last Name: Erickson
- * REQUIRED* Type and Year of Model Ts owned: 1920 Speedster
Free: approx 4 lbs (roughly 250 - 300 pcs.) Truss head (or mushroom head or brazier head) rivets, with a 3/16" x 1 1/4" shank, made of what I'm pretty sure is mild steel. Some surface rust is present but they should clean up pretty easily. I believe these would be well-suited for riveting wood slats to a steel frame, as you would on a pickup bed or depot hack body, as long as the wood isn't too thick. You pay shipping, of course.
Also some other weird rivets I'll never use: Approx. 3000 pcs Brass semi-tubular hollow rivets, measuring 9/64" diameter and a shank lenght of 3/16. They came in a box that was labeled "34 Chevrolet" so I'm guessing these might fit on a clutch disk or brake shoe for a 1934 Chevy. You pay shipping.
And finally a bunch of small aircraft rivets, solid aluminum with flat heads for countersunk holes, surplus old stock probably ca. 1950. They measure approx. 0.095" (3/32") diameter and the overall length is 0.26", the shank length is approx 0.21". Of course it will take hundreds of these rivets to make up 1 1/2 lbs. You pay shipping.
Thanks for looking.
Thanks for looking.
Richard K
- Last Name: Kemp
- * REQUIRED* Type and Year of Model Ts owned: 1926 TT Tow Truck
Re: Free: Steel Truss Head Rivets 3/16" x 1 1/4"
Pm sent for steel rivets. Thanks Rich
Rodger Erickson
Still have plenty of rivets left. Thanks for looking!
catfishunter99
- First Name: LORIEN
- Last Name: HEGNER
PM sent for the brass rivets
- First Name: craig
- Last Name: leach
Hi Rodger,
Rivets arrived yesterday. Thank You.
Rodger Erickson
There's still plenty of the Steel Rivets left if anybody wants some of them.
Rodger Erickson
I found more of these let me know if you want some thanks
Rodger Erickson
Any of you guys need any more steel rivets? I've still got a bunch!
