Wood coil box radius?
Topic author - Posts: 271
- First Name: David
- Last Name: Schwab
What is the radius on the corners of the wood coil box? I figured it was 1/4”, but looking at my bit it looks like that might be too much.
Re: Wood coil box radius?
I would say 1/4" is way too much. That's equivalent to 1/2" diameter. If you were to measure the circumference of the bend at 1/4" that would be closer. A machinist should have a set of radius gauges with which you can measure it accurately.
