Need blker. Distributor
Philip
First Name: Philip
Last Name: Thompson
* REQUIRED* Type and Year of Model Ts owned: 1924 touring
Post by Philip » Mon Aug 22, 2022 8:02 pm
If anyone has any info on the jess. blker. Belt drive distributor let me know
Philip
First Name: Philip
Last Name: Thompson
Re: Need blker. Distributor
Post by Philip » Mon Aug 22, 2022 8:05 pm
I meant jess. Blker.
Dan McEachern
First Name: DAN
Last Name: MCEACHERN
Post by Dan McEachern » Mon Aug 22, 2022 8:17 pm
Used a Chevy Vega 4 cyl distributor, a pair of timing belt pulleys- one on the dist shaft and one on the cam nose. A simple bracket mounted the distributor horizontally with the cap to the rear. Pretty sure a few of them are out there still running.
Philip
First Name: Philip
Last Name: Thompson
Post by Philip » Mon Aug 22, 2022 9:31 pm
I think I have one I have to get some pulleys and a belt
BRENT in 10-uh-C
First Name: Brent
Last Name: Terry
* REQUIRED* Type and Year of Model Ts owned: 1909 Tourabout, 1914 Runabout, 1915 Touring, 1916 Speedster, 1925 Speedster, 1926 Hack
Post by BRENT in 10-uh-C » Tue Aug 23, 2022 11:14 am
I (somewhere) have a new, never installed a Jess Blaker distributor kit. Let me look in my lower building later today or tonite.
Cordes_jeff
First Name: jeff
Last Name: cordes
* REQUIRED* Type and Year of Model Ts owned: 25
Post by Cordes_jeff » Mon Aug 29, 2022 11:29 am
I copied the design. It was a cheap solution for a decent ignition.
Philip
First Name: Philip
Last Name: Thompson
Post by Philip » Tue Jul 18, 2023 8:44 am
does anyone have any information on these units i have parts but not the bearings
jelloearnest
First Name: Billy
Last Name: Wade
Post by jelloearnest » Tue Jul 18, 2023 9:52 am
It sounds like you are describing a custom setup for a Chevy Vega 4-cylinder engine that uses a timing belt pulley system to drive the distributor. It's interesting to hear that this setup is still being used by some individuals and may be a viable alternative to traditional distributor setups.dumb ways to die
Philip
First Name: Philip
Last Name: Thompson
Post by Philip » Tue Jul 18, 2023 10:17 am
yes i have the bracket and a badly worn vega dist. made by jess blker. i bought a new dist.
but i would like to see how jess did the bearing
Post by TRDxB2 » Tue Jul 18, 2023 10:54 am
This is a 009 VW version (By Bob Doris, AZ on Wednesday, May 23, 2018) of the Jess Blaker distributor https://www.mtfca.com/discus/messages/8 ... 1536630758
Les Schubert
First Name: Les
Last Name: Schubert
Post by Les Schubert » Tue Jul 18, 2023 8:53 pm
Here is my version of using the Vega distributor.
Gear driven.
Philip
First Name: Philip
Last Name: Thompson
Post by Philip » Wed Jul 19, 2023 6:19 am
Did you cast the body?
Les Schubert
First Name: Les
Last Name: Schubert
Post by Les Schubert » Wed Jul 19, 2023 9:41 am
I machined it from two pieces of aluminum and then welded
Les Schubert
First Name: Les
Last Name: Schubert
Post by Les Schubert » Wed Jul 19, 2023 9:44 am
For the shaft and bearings I bought what is referred to as a “water pump shaft “
Les Schubert
First Name: Les
Last Name: Schubert
Post by Les Schubert » Wed Jul 19, 2023 5:08 pm
The “traditional” approach to timing a automatic advance distributor is teeing a vacuum gauge into the system and adjusting the timing for maximum vacuum at idle
Philip
First Name: Philip
Last Name: Thompson
Post by Philip » Wed Jul 19, 2023 8:38 pm
Thanks les. My question is would I be better of with manual advance with this setup
