If you need help logging in, or have question about how something works, use the Support forum located here
Support Forum
Brian D
- First Name: Brian
- Last Name: Dowell
- * REQUIRED* Type and Year of Model Ts owned: 14 Touring 26 Runnabout 19 Canadian Touring
Post
by Brian D » Wed Aug 24, 2022 10:24 am
Trying to help out a new guy.
Probably any key may work, especially a 55, however he wants a matching key
No numbers on this key.
Anyone tell what number this maybe!
Life is Good, be nice.
Post
by TXGOAT2 » Wed Aug 24, 2022 10:29 am
The later style switches have the key number stamped in the lock cylinder beside the key opening. The numbers are small.
Post
by RajoRacer » Wed Aug 24, 2022 10:32 am
Does the switch plate have "Ford" in script under the headlight lever ? If not, it's most likely an aftermarket & likely a # 55 key if not stamped on the cylinder.
George Mills
- Last Name: Mills
Post
by George Mills » Wed Aug 24, 2022 11:06 am
Really hard to tell without the other keys to compare. (my keyboard is at the winter house)
Ford only had 4 tumbler notch (teeth) combos, the rest was done with the groove locations on the blade.
Here is a picture of a keyboard with a set of keys...maybe you can zoom up and see????
Post
by TRDxB2 » Wed Aug 24, 2022 11:49 am
Looks like MAc's/Ecklers took the time to photo ever key individually. #55 guesses appear to be correct
https://www.macsautoparts.com/catalogse ... %20t%20key
Post
by Norman Kling » Wed Aug 24, 2022 1:12 pm
Even the ones you buy aftermarket do not always work. I have a key for my car and it happens that a friend has a car with the same key. He got one at either a swap meet or on line with the same number, but it didn't work. Finally found one that worked. The aftermarket keys are not always ground exactly right.
Post
by Mark Gregush » Wed Aug 24, 2022 2:11 pm
Had a customer's car with replacement 55 tumbler and key. If you inserted the key all the way it would not work, if left about 1/8" out it was fine.
Brian D
- First Name: Brian
- Last Name: Dowell
Post
by Brian D » Wed Aug 24, 2022 3:13 pm
Sure looks like 55 as many said.
I'll get a 55 and try!.
Thank you all,
Brian
Post
by TRDxB2 » Wed Aug 24, 2022 3:31 pm
If a new key doesn't fit properly in a 100 year old pot metal lock - could it be the lock and not the key?
Post
by RajoRacer » Wed Aug 24, 2022 4:04 pm
When you get a look at the switch assembly, let us know if it's Ford script under the light handle, please. Maybe even post a photo.
Some years ago, some of the repro black switch plate assemblies all used a #55 key and it could be removed in ALL positions !
Ed Fuller
- First Name: Ed
- Last Name: Fuller
- Board Member Since: 2012
Post
by Ed Fuller » Wed Aug 24, 2022 4:44 pm
If there is no number or Ford script on the key or the ignition switch, then that key is for the reproduction ignition switches.
A #55 key may or may not work. The tooth profile is similar to a #55 but there are some distinct differences. It all depends on how worn out the cylinder and the key are.
Brian, I sent you an email through the forum. I can help you out with the key.
J1MGOLDEN
- Last Name: Golden
Post
by J1MGOLDEN » Fri Aug 26, 2022 7:28 pm
The after marked switch keys and cylinders are cut like a #55 Ford key, but that groove is centered and not offset like the #55 Ford key, so they do not interchange.
Post
by Original Smith » Sun Aug 28, 2022 6:04 pm
I have a NORS C.D. switch assembly, and it is exactly the same as the Ford issue, except there is no script under the headlight switch lever. Also, the back of the assembly is bare metal.
