who sells fun projects regulator?
NY John T
Last Name: Killelea
Post by NY John T » Fri Sep 09, 2022 11:23 am
Does anybody know of a source for the Funprojects voltage regulators?
John bevardos
Last Name: bevardos
* REQUIRED* Type and Year of Model Ts owned: Roadster, Coupe, pickup truck, 2-door
Re: who sells fun projects regulator?
Post by John bevardos » Fri Sep 09, 2022 11:27 am
wish I knew....mine needs repair .
Who's still makes these gaskets, I might be in the market for a solid copper one myself.
Chris Barker
First Name: Chris
Last Name: Barker
Post by Chris Barker » Fri Sep 09, 2022 11:39 am
Search the Forum.
Discussed at length earlier this year.
The 'chip' is no longer available.
There are some DIY circuits suggested. Surprisingly complex!
Post by Scott_Conger » Fri Sep 09, 2022 11:46 am
John
if you are able to find a regulator, you MUSTMUSTMUST get the output tamed on your generator first (based on your other thread) and then follow the instructions that come with the regulator.
NY John T
Last Name: Killelea
Post by NY John T » Fri Sep 09, 2022 12:27 pm
I'll be away till early October and will get back at it then. Thanks all.
John
Post by TRDxB2 » Fri Sep 09, 2022 3:06 pm
Birdhaven in Colfax Iowa, purchased Funprojects, Texas T Parts and most recently Bob's Antique Auto Parts. It appears that the inventory of the products that these suppliers were noted for have run out. I and others have sent emails to Birdhaven that remain unanswered. The only WEB site they still have is Texas T and that doesn't reference many Model T parts. The do have a wide selection of parts but you need to call to ask & order.
and to answer your initial question "who sells fun projects regulator?" no one .
Luke
First Name: Luke
Last Name: P
* REQUIRED* Type and Year of Model Ts owned: 1926
Post by Luke » Sat Sep 10, 2022 3:53 pm
Search the Forum.
Discussed at length earlier this year...
viewtopic.php?f=2&t=25609
tdump
First Name: Mack
Last Name: Cole
Post by tdump » Sat Sep 10, 2022 4:38 pm
Yea,it is a loss to the hobby when there is good stuff out there and the big fish eat the little fish and then there is nothing left. When 1 company buys another,you can forget the other's products were ever there.
Similar happened when i needed a rebuild kit for a brake cylinder on my tandem trailer.company was bought by the competition,literally to eliminate it is what the man said on the phone.
Been Here Before
First Name: George John
Last Name: Drobnock
Post by Been Here Before » Sun Sep 11, 2022 2:09 pm
From Internet search:
https://www.cool386.com/
""In recent times (end of 2021), there has been a lot of interest on the MTFCA forum about voltage regulators, since the Fun Projects regulator is in short supply. It has certainly been a popular accessory over the years, and from all reports, as well my own experience, it works very well. With some encouragement from forum members Mike Kossor (the designer of the ECCT, E- timers, and I-Timers), and Luke, a fellow electronics and Model T enthusiast, I decided to finish my project.""
https://www.cool386.com/regulator/regulator.html
https://www.cool386.com/ford_regulator/ ... lator.html
You do not have to be an engineer, any one can fit a square peg into a round hole...with the proper hammer.
greenacres36
First Name: Brian
Last Name: Williams
* REQUIRED* Type and Year of Model Ts owned: 1926 Tudor, 1915 Runabout
Post by greenacres36 » Sun Sep 11, 2022 8:27 pm
I just finished a mod to my generator to give a high and low charge rate. It was very simple and fairly discreet. I put an insulated screw on the band cover and moved the ground lead from the field coil off of the grounded brush to the insulated screw. I suppose you could use a voltage regulator there but instead are used a ballast resistor that was 1.8 ohm in resistance. I grounded one side of the resistor and attached a wire to the insulated screw that I put in the band cover. This would give a reduced charge rate. Then I ran a wire from the insulated screw through a toggle switch and then to ground. When the switch is in the on position it would give full charge to whatever the third brush is set at. With the switch in the off position it would roughly half that. I’m just tickled pink by it. The whole deal cost me about $10. And it fairly keeps the original appearance by still using the diode cut out. I believe I heard that you can put a five amp fuse in with the field coil circuit that will protect the field coil in case the cut out fails. I have not tried that yet but was considering putting a fuse in that ground wire before the insulated screw. I don’t know if that will accomplish anything. If my memory serves me right, I believe there has been prior discussion about putting a fuse in that field circuit to protect from a runaway generator in case of a cut out failure.
Brian
Post by Scott_Conger » Sun Sep 11, 2022 8:36 pm
Post by TXGOAT2 » Sun Sep 11, 2022 9:11 pm
I intend to bring the field ground wire out through an insulated terminal in the generator body, leaving the third brush arrangement intact. I believe that would allow using a 2 or 3 element 6 volt Delco type regulator for automatic general regulation and using the third brush to pre-set a fixed limit on the maximum charge rate. Alternatively, resistance could be manually switched into the field circuit rather than use the Declo regulator.
greenacres36
First Name: Brian
Last Name: Williams
Post by greenacres36 » Sun Sep 11, 2022 9:27 pm
Thank you Scott for showing that post. I thought I remembered it but you know how things go as you get older. L O L my thought also was to include a Delco style regulator but I didn’t want to spend the money upfront and what I’ve done is satisfactory for me now. If someone actually has done or does do the Delco regulator I would be interested in to see how that works. In my opinion it’s a reasonable solution, and an excellent upgrade for a car that is driven regularly.
fschrope
First Name: Fred
Last Name: Schrope
* REQUIRED* Type and Year of Model Ts owned: 1923, 1926, 1927 TT's, 1918 cutoff touring, 1922 Coupe - original
Post by fschrope » Sun Sep 11, 2022 10:08 pm
Amen. I agree 100%
