Bendix drive gear pin
tom_strickling
Last Name: Strickling
* REQUIRED* Type and Year of Model Ts owned: 11 Torpedo, 18 Touring, 21 TT Huckster, 24 Roadster,snowmobile, Shaw tractor conversion
Post by tom_strickling » Fri Sep 09, 2022 4:24 pm
What is the purpose of the little spring loaded pin inside the bendix drive GEAR and how important is it. I have included a link to a catalog photo of the part. THANKS !
https://www.modeltford.com/item/5021PS.aspx
“The trouble with retirement is that you never get a day off.” – Abe Lemons.
Re: Bendix drive gear pin
Post by TXGOAT2 » Fri Sep 09, 2022 4:36 pm
That's to provide a controlled amount of friction. It is important.
First Name: craig
Last Name: leach
Post by Craig Leach » Fri Sep 09, 2022 4:49 pm
Keeps the starter gear from randomly getting into the ring gear while the engine is running.
Ron Patterson
Post by Ron Patterson » Fri Sep 09, 2022 5:59 pm
It is called an "anti-drift" pin and holds the drive gear in its quiescent resting place so it does not vibrate back down the threads into the ring gear.
Ron Patterson
Ron Patterson
Post by Ron Patterson » Fri Sep 09, 2022 6:10 pm
When the starter is powered up, the high torque of the motor forces the spring loaded pin upward out of the groove and allows the drive gear to screw down the drive sleeve, approach and engage the ring gear to turn the engine over to start. The ratio of the Bendix drive gear and ring gear is a ratio of 12 to 1. Hence the starter 12 foot pounds of is multiplied by 12 to apply 144 foot pounds of torque to the crankshaft for starting.
Ron Patterson.
tom_strickling
Post by tom_strickling » Sat Sep 10, 2022 7:54 am
Thank you!
