Early Tire Irons
Russ_Furstnow
First Name: Russ
Last Name: Furstnow
Early Tire Irons
Post by Russ_Furstnow » Wed Sep 14, 2022 10:55 am
I had the opportunity to acquire these tire irons from the estate of the late Phil Knighton, along with some speedometers and clocks. I was unaware of the variety of tire irons produced by tire manufacturers. I know that some of these tire irons were included in early Ford tool kits (Diamond and Firestone) but I don't know if any others were included in the kits. Russ Furstnow
Re: Early Tire Irons
Post by Original Smith » Wed Sep 14, 2022 11:03 am
I'm only commenting on the Diamond brand, because that is what Ford seemed to use, although it seems logical the ones pictured in the parts books could certainly be Firestone or even Fisk. I've seen two different designs of Diamond tire irons. Some have a bump toward the end, and some don't.
Russ_Furstnow
First Name: Russ
Last Name: Furstnow
Post by Russ_Furstnow » Wed Sep 14, 2022 11:34 am
This Diamond tire iron has the "bump." The Diamond tire iron is illustrated in the early parts books, but that does not mean that was the only one that was used in the tool kits. Another example of this is that the 1915 Accessory Parts booklet illustrated only the Jones speedometer, and we know there were four other brands of speedometers used in 1915.
Ed Fuller
First Name: Ed
Last Name: Fuller
Board Member Since: 2012
Post by Ed Fuller » Wed Sep 14, 2022 9:09 pm
What a great collection of tire irons!
Thanks for sharing the pictures.
Post by Allan » Wed Sep 14, 2022 9:17 pm
I have only found Goodyear irons in Australia. I have two surplus to requirements, but they are not a matched pair. One has a longer depression for the Goodyear script than the ones Russ shows.
