Connecting Rods
Bill Johnson
First Name: Bill
Last Name: Johnson
* REQUIRED* Type and Year of Model Ts owned: 1925 Coupe, 1926 Roadster, 1927 Fordor, 1914 Touring project
Connecting Rods
Post by Bill Johnson » Wed Sep 14, 2022 10:59 am
Is there a way to identify connecting rods without weighing them? The weight might vary because of missing or damaged babbit. Ford may have used several suppliers for the rods but were any stamped ith a part number or identifier of some kind?
First Name: craig
Last Name: leach
Re: Connecting Rods
Post by Craig Leach » Wed Sep 14, 2022 1:17 pm
Re: Connecting Rods
Post by John kuehn » Wed Sep 14, 2022 1:31 pm
The older rods look wider through the web of the rod. They are fairly easy to tell from the later lighter rods. Most of the suppliers won’t accept the older rods for exchange because of the older design and weight. They won’t rebabitt them. Or they use to not do it.
Re: Connecting Rods
Post by Mark Gregush » Wed Sep 14, 2022 11:38 pm
Yes the rods were forged with makers mark, but there are too many to list here. While the marks are shown in the Service Bulletin Essentials, they are not cross referenced to which type rods they go to, except maybe by using the date when Ford posted the charts, but that might not be helpful, as the same company could have made different weight rods.
There are 3 types of rods, heavy, medium and lite. Medium and lite are really close. Looking at where the shank meets the part where the babbitt is poured; heavy is about 1" across, medium is about 7/8" and lite is about 5/8".
Craig, you may be posted the wrong link?
First Name: craig
Last Name: leach
Re: Connecting Rods
Post by Craig Leach » Thu Sep 15, 2022 1:19 am
Yes Mark I did. Try mtfca.com/discus/messages/506218/585921.html?1448347389 Or model T forum light rods vs heavy
Bill Johnson
First Name: Bill
Last Name: Johnson
Re: Connecting Rods
Post by Bill Johnson » Thu Sep 15, 2022 11:43 am
Mark,
This helps.
Thank You
Re: Connecting Rods
Post by Mark Gregush » Thu Sep 15, 2022 2:32 pm
