Zenith Model B carb
Tmooreheadf
Last Name: Moorehead
Zenith Model B carb
Post by Tmooreheadf » Fri Sep 23, 2022 7:27 am
Looking for a Zenith model B carburetor rebuilder or someone who has rebuilt B carbs available outright or exchange!
Tom
Last Name: Wrenn
Re: Zenith Model B carb
Post by TWrenn » Fri Sep 23, 2022 8:09 am
Try Russ Potter...maybe he has?
GG Gregory
First Name: GG
Last Name: Gregory
* REQUIRED* Type and Year of Model Ts owned: 27 Roadster
Post by GG Gregory » Fri Sep 23, 2022 3:50 pm
Message sent
Jim Eubanks
First Name: Jim
Last Name: Eubanks
* REQUIRED* Type and Year of Model Ts owned: 1926 touring, 1927 cpe
Post by Jim Eubanks » Fri Sep 23, 2022 5:33 pm
Tom, What is wrong with it. Rebuilding usually consists of cleaning, a new float needle and seat and new gaskets. If the shafts are not worn, usually a good cleaning and air blow will make the old zeniths run fine. IMHO the old solid float needles are better than the replacements. The only wearing parts are the shafts and the float needle.
Tmooreheadf
Post by Tmooreheadf » Fri Sep 23, 2022 8:59 pm
I have done all the cleaning as before and the carb runs fine with the exception of idle. Coming to a stop, engine dies every time. It was running great and just starting doing this the first of the week. Got to be a piece of crud maybe, but cleaning has not corrected it. I’m going to do a compression check tomorrow just to eliminate that as a cause. The idle circuit seems to be the issue.
Post by Scott_Conger » Fri Sep 23, 2022 9:29 pm
Doing a compression check will be instructive I suppose...but it won't provide any information at all, relative to stalling when coming to a stop
it sounds like one of two things: your idle jet is still partially restricted and based on that assumption, it is time to remove jets again and give things a prolonged ultrasonic cleaning followed by reassembly and adjustment; or, your float level is maladjusted.
A third, though less likely problem is a slight vacuum leak at the mounting flange (or the motor). When the fuel surges in the bowl, the jets can see the fuel level drop...combined with a leak at high vacuum, you can go suddenly and temporarily quite lean.
here is a very good explanation of how Model A-B carbs work, including all circuits: http://modelabasics.com/carberutor.html
ModelTWoods
First Name: Terry
Last Name: Woods
Post by ModelTWoods » Fri Sep 23, 2022 10:30 pm
Tom
Tom, I sold you two. Who rebuilt those carbs? I thought you did. What happened?
